Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby limitedblack » Sat Dec 07, 2013 10:31 am
Without reading through, where did this carb come from, is it new, if not what was it on???
Happy Easter
limitedblack
Postby jonochap » Sat Dec 07, 2013 4:05 pm
It was a very kind deal with Robbie Cee on here, he had it on his mk3 pinto...i originally had a weber 34 new in box to fit but it got stolen before i could afford to fit it :(
I have got it running smoother now but it still has a backfire when you turn the engine off...doh!
Owner of not so troubled puk :)
jonochap
Postby limitedblack » Sat Dec 07, 2013 4:49 pm
Still sounds like timing issue, cam possibly, but I know you said you have done that.
Happy Easter
limitedblack
Postby Muttley » Sat Dec 07, 2013 8:41 pm
For the record, the cam timing is spot on, the tappets are spot on, the Weber is an unknown quantity. Timing is (or was Jono) spot on. There is an issue with the insulator block and gaskets beneath the carb and also a nut on the back of the carb to manifold that will not fully tighten. I will replace the Weber with another carb, VV or ICH but in the meantime Jono is addicted to turning screws and rotating distributors and despite receiving therapy for this he is unable to break the habit. Indeed, I firmly believe that even when this van runs spot on he will still fiddle with it. Its a sad thing but with all our help I think we can break poor Jono of this habit. I may fit a new carb with tamperproof screws and weld the dizzy in the right place if he cant give up, meantime all we can do is hope, thank you all for understanding :mrgreen:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby limitedblack » Sat Dec 07, 2013 9:21 pm
Weld up that bonnet ;) Jono, NO TOUCHY !
Happy Easter
limitedblack
Postby jonochap » Sun Dec 08, 2013 3:36 am
I hate fiddling more than you would ever know! Once it is all right i gladly sit on the bonnet as you all weld it down!
Mutts, i didnt mean to cast aspersions on any of the work you have done! Robbiemate im sure your carb is a great one. I am just trying to keep a little piece of history nice and i feel with the expertise on here i have alot to live up to.
Im sorry my efforts are seen as so destructive.
jonochap
Postby limitedblack » Sun Dec 08, 2013 8:04 am
I think what everyone is saying is something's broke, fiddling isn't going to fix it.
I had a mini that was tuned up, in theory it runs better with a vacuum distributor, but no matter what I tried it wouldn't run right, in the end I ordered a special non-vacuum one, ran much better after that.
At the same time I had a pinto with a wiring fault for the ignition coil, that ran lumpy, started fine, just lumpy.
If someone has set up all the timing correctly, and adjusting the carb doesn't bring it into tune, then adjusting the timings will only send you backwards, bringing too many variables back in :)
A different carb as said is your next step, sure it will run fine soon. Have you tried another hobby like matchstick models or domino stacking ? :lol:
Happy Easter
limitedblack
Postby jonochap » Sun Dec 08, 2013 10:55 am
Thank You LB. I am very very excited as to Mutts next visit as it makes massive good stuff happen.
jonochap
Postby Mad machinist » Mon Dec 09, 2013 5:26 pm
Just to save me trawling all through posts, was the initial 'misfire' effect whilst on a trailing throttle, ie when deaccellerating?, if so, your problem is more likely to be a leak on an exhaust joint, any where on its length, happy hunting
A subsiduary of Heath Robinson Developments
Mad machinist
Postby Muttley » Mon Dec 09, 2013 11:08 pm
The initial (and continuing) misfire is in Jono's head :wink: :lol:
Muttley
Postby jonochap » Tue Dec 10, 2013 12:48 am
Yeah yeah...look forward to seeing yer Mutts man, let me know when :)
jonochap
Postby Mad machinist » Tue Dec 10, 2013 11:13 am
Mutt, suggest seal all leaks in Jonos head, lol
Mad machinist
Postby jonochap » Tue Dec 10, 2013 10:43 pm
Aw fanks MM...im not sure my head will work well with a welder but he sure wont be the last person to try :)
jonochap
Postby Muttley » Wed Dec 11, 2013 1:25 am
Mad machinist wrote:Mutt, suggest seal all leaks in Jonos head, lol
Yeah, I gotta get some sense in there first though :lol:
Muttley
Postby jonochap » Wed Dec 11, 2013 7:23 pm
Yeah, like you've all got some to spare :)
jonochap
