Gets everywhere dog hair
Miss allcock gets it in her bra
I'll have to try the air line thing on her
bigjohnthomas wrote:Have you done that mirror thing yet ?
loot wrote:Dunno what all the fuss is about![]()
1 little relay, 1 wire cut, bobs your aunty.![]()
https://youtu.be/RjUO9r5QXwU
https://youtu.be/NeBz9Sh-HZ8
Needs fine tuning tho, unlock is too fast first time so it flinches and you have to press unlock again, nothing happens on single lock (as me and allcocks engineering wanted) then double lock does it, presently it is dumb so can keep doing it on multiple presses and can be opposite so i expect it'll get quite annoying at some point until modification of some kind can be made
Well what do you want for nought like?
loot wrote:Used a hair dryer in the 240v outlet with the engine running to heat up the hilti vinyl on the roof and remove itmakes a hell of a difference with it hot, cold and it just shatters, got and it came off in large pieces, had to partially lie with 1 leg along the roof and the other on the Hilti chair in the side. Lucky i had the pram rails to hold.
Bit annoyed because the rear rubber bung has had a sharp blade around it to install the vinyl and there is brown there which I'm going to lacquer over once i clean it.
Found some turtle wax compound in the garage new in the tub, might have a little look see
My invertor is only 1000w so no abuse it cuts off
PheoBlue wrote:loot wrote:Used a hair dryer in the 240v outlet with the engine running to heat up the hilti vinyl on the roof and remove itmakes a hell of a difference with it hot, cold and it just shatters, got and it came off in large pieces, had to partially lie with 1 leg along the roof and the other on the Hilti chair in the side. Lucky i had the pram rails to hold.
At least you only had the roof I got the whole thing, and it's not responding very well to the heat , still breaks off in tiny little pieces.![]()
Sent from my SM-G930F using Tapatalk
