Loots Red custom
Re: Loots Red custom
Postby loot » Sat Apr 22, 2017 1:37 pm
nedforceone wrote:Going to have to get myself a couple of them, hope its easy to do as am a bit dumb when it comes to electrics, I'll probably end up with the wipers activating instead of the windows closing :lol: N
It's looking quite simple at the moment but i think my interface it's broken because it isn't latching 8)
Fortunately i have another bit it is in loots lost and found at work, suppose i best get it eh :D
Ids map here
loot
Postby bigjohnthomas » Sat Apr 22, 2017 5:48 pm
Get a steam wallpaper stripper on those stickers young man
That way you won't pull the paint off
Not much of it anyway
Relay for loots folding mirrors ordered, one with a timer on for extra weirdness :D
https://www.ebay.co.uk/itm/272040805896&seller=&toolid=10018&34601013" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/272040805896&seller=&toolid=10018&34601013" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/272040805896&seller=&toolid=10018&34601013" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/272040805896
I leave my van front doors locked back doors wide open and the front windows down an inch or 2 so self closing windows are not for billy, I like to let excess gasses out :P
bigjohnthomas
Postby bambi mk 1 » Sat Apr 22, 2017 5:56 pm
loot wrote:
PheoBlue wrote:
loot wrote:Used a hair dryer in the 240v outlet with the engine running to heat up the hilti vinyl on the roof and remove it :mrgreen: makes a hell of a difference with it hot, cold and it just shatters, got and it came off in large pieces, had to partially lie with 1 leg along the roof and the other on the Hilti chair in the side. Lucky i had the pram rails to hold.
Bit annoyed because the rear rubber bung has had a sharp blade around it to install the vinyl and there is brown there which I'm going to lacquer over once i clean it.
Found some turtle wax compound in the garage new in the tub, might have a little look see :D
My invertor is only 1000w so no abuse it cuts off :(
At least you only had the roof I got the whole thing, and it's not responding very well to the heat , still breaks off in tiny little pieces. Image
Sent from my SM-G930F using Tapatalk
Try it a little hotter, not too hot tho.
ImageThese are the mutts nuts :)https://store.snapon.com/Pinstripe-Remo ... 50767.aspx
bambi mk 1
Postby PheoBlue » Sat Apr 22, 2017 9:06 pm
bigjohnthomas wrote:Get a steam wallpaper stripper on those stickers young man
Thanks for the suggestions guys , would have tried it today . But made the most of the sunshine and did the 2 lower wishbones.
PheoBlue
Postby loot » Sat Apr 22, 2017 10:06 pm
Careful with this because the circuit swaps continuity :idea:
My relay is a dummy and can be actuated 1 polarity or the other and it is a single circuit.
Ids map here
loot
Postby bigjohnthomas » Sat Apr 22, 2017 11:40 pm
:? Oh bolloks I need a relay to activate the relay then :lol:
bigjohnthomas
Postby loot » Sun Apr 23, 2017 9:40 am
bigjohnthomas wrote::? Oh bolloks I need a relay to activate the relay then :lol:
I've looked and i think i just need a small capacitor 47k which will store power and hold the relay open for a second which will make it work and then to for 1 maybe 2 diodes to protect the capacitor from reverse voltage on double lock.
Hang fire I'll have a look today
Ids map here
loot
Postby bigjohnthomas » Sun Apr 23, 2017 10:50 am
Who ? What ? :P
I'm hanging man .. 8)
bigjohnthomas
Postby loot » Sun Apr 23, 2017 12:38 pm
Did you forget your underpants again? :lol:
Watching the running just now then I'll get my iron hot :P
Ids map here
loot
Postby loot » Sun Apr 23, 2017 7:09 pm
I've done it, or I've made a bomb :shock: :lol:
[URL=http://s1251.photobucket.com/user/loots1/media/14929710159501_zps6xkccyhg.jpg.html]Image
Image[/URL]
https://youtu.be/77-0eNYhU0U
Doesn't work if i add a diode or resistor for protection although i was using a 20v dyson battery to test.
No diode or resistor and it works, ironically it works in both polarity :shock:
It stayed cold the correct polarity but got hot in reverse, that said i had to keep actuating it with 20v for it to get hot, it states 105c (probably safe limit)
Ids map here
loot
Postby bigjohnthomas » Sun Apr 23, 2017 7:36 pm
Have you fixed it dad :lol:
bigjohnthomas
Postby loot » Sun Apr 23, 2017 7:43 pm
It works on the van, there's less voltage than the battery but it still works, one unlock opens the mirrors and double lock closes the mirrors.
I have to install it into the van now and try it out for a bit.
Ids map here
loot
Postby loot » Mon Apr 24, 2017 2:01 pm
All back together, system is dead when no buttons pressed, lock sends a 0.5s positive pulse to activate door locking actuator, and again for lock and again for deadlock, there's 2 motors, 1 moves forward for lock, 2 move forward for double lock then both reverse for unlock.
https://youtu.be/PZhJ6DoFl-E
Finished, works fine, unlocked the boot and the mirrors opened then i pressed front unlock and they started open 8)
Ids map here
loot
Postby bigjohnthomas » Mon Apr 24, 2017 2:35 pm
Splendid 8)
all that remains to do is a how too :P
bigjohnthomas
Postby loot » Mon Apr 24, 2017 4:45 pm
Not much to it really bjt :D
I'll do more testing in everyday life but i think it is all good.
Have put the door card back on but am waiting for the electric window automatic roll up module to arrive, even tho motorworld man said there's no such thing and i need to go home and Google it and do my homework :lol:
What a bell end :roll:
Ids map here
loot
cron
