Red one
Re: Loots mk7 keeper
Postby loot » Sat Jul 27, 2024 11:18 pm
So the drivers side under sill panel is rusty and holed so I thought I could fit the step box section and small sill but I'm thinking just get the side door stuff in.so I've started removing the panel :P
Ids map here
loot
Postby loot » Mon Aug 19, 2024 8:09 pm
Inner front arch fitted and a bit of plate work on the step .
The underseal will hide the ergh but it is rot free. :P
Quote for the side door panels is quite expensive. But finding a rwd drivers side sliding door donor vehicle is rare
Ids map here
loot
Postby Altransit » Mon Aug 19, 2024 9:53 pm
Wassup with the SLD, I thought they were galvanised :?
Postby loot » Tue Aug 20, 2024 5:25 pm
Altransit wrote:Wassup with the SLD, I thought they were galvanised :?
I'm not sure what you mean Al?
Ids map here
loot
Postby Altransit » Tue Aug 20, 2024 9:01 pm
I mean what's up with the SLD, why are you looking at changing it?
Postby loot » Wed Aug 21, 2024 2:55 pm
Altransit wrote:I mean what's up with the SLD, why are you looking at changing it?
Oh Al my good fellow, I'm not looking at changing it........ I'm adding it :P
I know it's more crazy an adventure than the 1 bilbo baggins went on in the hobbit but needs must when loot wants something. :lol:
I bought a tourneo to steal bits off but it turns out (at this point) that the tourneo is worth fixing and selling on. However with this being rwd there's a few panels that are different in the rear.
So buying them from ford might be costly.although some are only 25£ each. My plan is to do the floor sections and that means I can mot it.
Hence me procrastinating. :|
Ps nothing is galvanised
Ids map here
loot
Postby Altransit » Wed Aug 21, 2024 2:59 pm
loot wrote: Ps nothing is galvanised
Mk7 doors are :mrgreen:
Postby loot » Thu Aug 22, 2024 9:43 pm
:lol:
Ids map here
loot
Postby loot » Fri Aug 23, 2024 12:59 pm
Bit of a kick in the happy sac today :cry: contacted ford and the parts I asked for are obsolete and not manufactured any more.
Anyone got a sheet metal bender by any chance?
Ids map here
loot
Postby ned » Fri Aug 23, 2024 3:34 pm
Yes it’s called a vice and a hammer :lol: :lol:
Anyway more importantly, can the outside air temp sensor become faulty? Sorry to hijack your build thread but fanny thinks it’s -45 degrees, fridged bitch :lol: :lol: :lol:
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Fri Aug 23, 2024 6:01 pm
ned wrote:Yes it’s called a vice and a hammer :lol: :lol:
Indeed it can mr Ned, try unplugging it and plugging back in check contacts are clean etc. Drivers chassis leg front near fog light :P
Ids map here
loot
Postby Altransit » Fri Aug 23, 2024 8:50 pm
ned wrote:Anyway more importantly, can the outside air temp sensor become faulty? Sorry to hijack your build thread but fanny thinks it’s -45 degrees, fridged bitch :lol: :lol: :lol:
Mine is now on its third OAT sensor, and none of them have read correctly. The first one was the most wildly inaccurate, reading up to +45 degrees on a hot day, and down to minus 25 degrees in the depths of winter. The one that's on there now is the best (closest) of the bunch but still never tallies with the other cars :roll: :P
Postby ned » Sat Aug 24, 2024 1:25 pm
Thank you good Sir’s it’s good to know there a waste of time :lol: :lol: might just unplug it so it die keep bloody beeping up saying it’s cold
ned
Postby Altransit » Sat Aug 24, 2024 3:08 pm
It gets irritating cancelling the warning every two minutes. The low temp warning keeps popping up (around 4 degrees) when driving around the country lanes and the temp keeps changing slightly :(
Postby ned » Sun Aug 25, 2024 5:34 pm
I gave up and ordered a new sensor, the constant beeping was driving me slightly mad
ned
