sorry i did mean to do one but with all the running problems i have had with the van, trying to get it running properly, i haven't had time,
the wiper conversion is quite easy, all you have to do is cut and extened the small arm that is driven of the motor, you will need to add 9mm, then just take of the linkage to the drivers side wipper arm, i extened my passange arm about 2" and put a 24" wiper blade on it and i just messed abou to makesure it stops and moves equaol each side,
apart from that to make things look better i cut down the thred on the drivers side mount so just has the nut holding it on and it doesn't poke through the sucuttle panel.
i will try to take some pics later if it stops raining, if any one wants a conversion i will modd there own wiper assembley for a small fee, if they post it to me, and pay fo the materials only about £2.00-3.00, and the return cost of postage, i could also extend the wiper arm at the same time,
any way todays plan it to try and wire up the centrel looking motors that i have, i took them out my escort van and i have had a play with them and they fit on the transit lock mechanisim so now i have a haynes manual shouldn't take to long,
i am also running the looms for electric windows an electric mirrors just incase i come a cross a second hand set,
and the plan was to do some more of the bumper but its crappy weather out side,
fingers cross that it clears up or i will drive myself mad sitting in the house all day,
