Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby Luke » Tue Dec 27, 2011 8:59 pm
thought i did :oops: :lol: needs em fitted 8)
Postby mealic » Tue Dec 27, 2011 9:02 pm
robbie.cee wrote:
AlanN wrote:Yes he has Luke, you pilot drilled them for him, I reckon his keeping them for a surprise for us :lol:
yes they are in shed- can drill out t5he 13mm holes, but i neede a 60degree metal counter sinker. think ill ask captain hook nicely if he'll get his man with a metal shop to finish the holes!
I know someone that has one Robbie.If you could come along to the next Makeover and help bring some of the stuff from your way I`m sure that he might be there and lend it to `ya.How`s Emma these days?
`04 2.3 petrol/LPG
mealic
Postby MinorMatt » Tue Dec 27, 2011 9:20 pm
Is that someone I know Ali?
Postby mealic » Tue Dec 27, 2011 9:23 pm
MinorMatt wrote:Is that someone I know Ali?
As if like magic,he appears :lol: :lol: Is it Panto Season?
`04 2.3 petrol/LPG
mealic
Postby MinorMatt » Tue Dec 27, 2011 9:36 pm
oh no it isn't...
Postby Luke » Tue Dec 27, 2011 9:50 pm
moi :?: :lol:
Postby robbie.cee » Tue Dec 27, 2011 11:10 pm
mealic wrote:
yes they are in shed- can drill out the 13mm holes, but i need a 60degree metal counter sinker. think ill ask captain hook nicely if he'll get his man with a metal shop to finish the holes!
hi ya Ali, Emz is ok m8 cheers for asking. first scan tomo so we'll be up Basildon General tomo afternoon. half day off work, sweet!!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Jan 06, 2012 9:13 pm
Righto, thanks to Browny, for spotting this on ebay,
Bit of brasso cleaned it up well enough, just wish i owned a small/large car parts washer would be great, but "not til i've got a garage to put it in..." :?
More elbow grease then!
My neighbour Ade said he will help me fit it sunday.
few extra pipes on the manifold, dunno what goes where- looks like therre is a water port in the inlet manifold?? is this right??
Had
MAKE IT FIT
robbie.cee
Postby Luke » Fri Jan 06, 2012 9:18 pm
are you on about the pipe you can see in the pic :?: it's the auto choke that uses the water temperature :D
Postby robbie.cee » Fri Jan 06, 2012 9:29 pm
i see the water pipe from auto choke - goes bk into lower block of manifold???
also what is the middle hole for - threaded 1/2 " approx
and looks like vac spur too on far right?
cheers m8 :D
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Jan 06, 2012 11:07 pm
Any one got an idea what those other connections are for? :?:
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Sat Jan 07, 2012 8:36 am
Yeah :lol:
captain hook
Postby robbie.cee » Sun Jan 08, 2012 11:01 am
it looks like ill have to remove heater pipe, attach to choke , but the water from the choke goes thru another pipe, not bk to heater but into the manifold. theres an extra hole between the air ports i guess its a water port- bout inch by half inch rectangle?? is this a water cooled manifold?
help appreciated!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed Feb 01, 2012 12:28 am
Well not too much happening recently as it aint tropical! Wellers off being drilled and counter sunk, new windscreen on way as current one fooked by wipers last snow.... hopefully going in tomo!
cam belt and tensioner very soon, will hopefully sort timing out too in one hit then! might even get the better carb fitted this year too!
defo need a new starter mine has not quit but hinting greatly of retirement!!
had a little spend up on ebay got some led clusters to go in my clear front and side indicators. the front (21w) ones arrived today, £5.99 free postage, came in 2 days! will post piccy when i find where emma put usb lead for my phone.
also ordered mk1 escort steering hub boss and a snap off hub too! seen a wheel i really like too, what do you guys think...
http://www.ebay.co.uk/itm/220869798504? ... 1423.l2649
Had
MAKE IT FIT
robbie.cee
Postby transitandy » Wed Feb 01, 2012 3:36 pm
That steering wheel will look 8) on your van :)
