My 2.5 TDi project
Re: My 2.5 TDi project
Postby FEEZ92 » Thu Mar 01, 2012 1:21 pm
Sligobob; all the stuff was custom fabricated so I don't have any spares thrown around
SligoBob wrote:Alright buddy, do you have many spare bits knocking about? I'm looking to turbo my banana engine, so I'm looking for turbo, manifolds, pipework, sump, oil feed pipe, and exhaust front pipe...
Also looking for a lower ratio diff/axle or CW/P for my 6-stud single wheel axle.
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby Stavros » Fri Mar 02, 2012 3:43 am
Hi mate haw its going your 200hp project??? :mrgreen:
Like for me that imposible on this engine.
I have tuned 1.9TDI what in stoke was 142hp 340nm. I have change pump duses for race one, turbo charger for big from 3.0tdi, front intercooler from subaru impreza, fuly free flow exchaust 3", high flow head, bogger valves and race cam shaft. After that all modyfications and remap i have litle bit over 250 hp.
How you want to go over 150 on VP diesel ??????????? Is imposible with this pump and injectors iven if will burn 7MPG.
But about 120 shuld't be a problem.
Stavros
Wrong Again!
Postby FEEZ92 » Fri Mar 02, 2012 12:07 pm
The marine engines can get 160bhp from the K26 turbo and VE pump so hopefully I'll get more with pump modifications
Stavros wrote:Hi mate haw its going your 200hp project??? :mrgreen:
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby FEEZ92 » Fri Mar 02, 2012 5:01 pm
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby robbie.cee » Sun Mar 04, 2012 1:08 pm
hows it going feez? still doing the drift bus??
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby FEEZ92 » Sun Mar 04, 2012 4:38 pm
Hey robbie
Yes still at it. Progress is very slow due to work
I'm going to be fitting the turbo and modified pump in the next few weeks
robbie.cee wrote:hows it going feez? still doing the drift bus??
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Mon Mar 05, 2012 2:00 pm
Will be interesting to see one complete :D
200hp should be possible with the governor mods and big turbo :)
IgorVigor
Postby IgorVigor » Mon Mar 05, 2012 4:15 pm
I forgot to ask, what exhaust manifold did you use?
and where did you get those 130ps injectors from? 8)
IgorVigor
Postby FEEZ92 » Mon Mar 05, 2012 4:26 pm
The manifold is the standard n/a one and I welded on a T3 flange for the turbo.
The 130s came from diesel parts direct
IgorVigor wrote:I forgot to ask, what exhaust manifold did you use?
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby FEEZ92 » Mon Mar 05, 2012 4:34 pm
Does anyone have a good idea on how to lower the compression a bit without going for the turbo head or pistons?
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Mon Mar 05, 2012 4:57 pm
Thanks for the manifold and injector info :)
I might do a similar approach :lol:
as for lowering the compression, I thought Ford lowered the compression by using different pistons?
so the heads are the same (apart from the valves)
why do you want to lower the compression though?
19:1 should be fine....
but if you really want to, a spacer plate to lift the cylinder head a little might be the easiest option......
slightly longer pushrods would be needed though....
IgorVigor
Postby FEEZ92 » Mon Mar 05, 2012 5:09 pm
As far as I know they machined a dish between the valves, where the injector pokes through.
I don't want to stress the head gasket too much. The few points in compression equates to a lot of degrees ºC and EGTs and stuff.
I know the compression was lowered in the turbo di engines to reduce emissions and that
IgorVigor wrote:Thanks for the manifold and injector info :)
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Mon Mar 05, 2012 6:26 pm
Whaf exhaust will you be running?
Because a larger bore exhaust with no restrictions (so either no silencer or straight through) will lower the EGT's.....
And your big intercooler will keep the charge temp down which in turn will keep the egts down.....
Most of all though keep the smoke down a bit :P
I know a big plume from a turbo diesel looks good....but it will increase EGTs!
You could however.....fit a water injection system.....
IgorVigor
Postby FEEZ92 » Mon Mar 05, 2012 6:38 pm
3" side exit pipe. I might twin turbo it down the line
I'll be running enough boost to burn any amount of diesel
IgorVigor wrote:Whaf exhaust will you be running?
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby robbie.cee » Mon Mar 05, 2012 8:24 pm
Aren't NA dis 20.8:1 comp ratio?? wouldnt that extra bit make it more powerful, or just harder to squeeze the air in cylinder!! :?:
Had
MAKE IT FIT
robbie.cee
