mk1 bullnose pickup
mk1 bullnose pickup
Postby oldskooler » Sun Dec 11, 2011 3:48 am
im a long time getting round to starting this project but well keen to get stuck in!! i bought it off ebay well over a year ago, it had just came in from malta, body removed, running a toyota td engine. ive got a rotten mk5 donor van from which i intend to use engine, box and running gear including the ifs subframe/power steering rack etc.
heres a few pics from when i brought it home last year on marks recovery.
i had it tucked away in the uncles barn till i pulled it out the other day to get stuck in!!
ive just made a start on the stripdown, no major nasties so far, usual repairs needed in spots but no serious corrosion found as yet, hard to beat the maltese climate!!
front end off.
loom and brakes stripped out, lump and box next!!
more progress soon hopefully!!!
oldskooler
Re: mk1 bullnose pickup
Postby AlanN » Sun Dec 11, 2011 9:42 am
Poor thing is never gonna know what hit it after being Malta... what the hell is rain :lol: Looks like a good starting point for a project, keep it coming :D
Postby blue estate » Sun Dec 11, 2011 10:06 am
Love the toyota engine in it :shock: the owner must have been feed up with the 0 to 60 in a week from the old ford lump :lol:
blue estate
Postby blue estate » Sun Dec 11, 2011 10:08 am
Minnor mat must have painted it as it's got as many differant colours on as his mk5 :lol:
blue estate
Postby G40GES » Sun Dec 11, 2011 10:11 am
love the CONTINENTAL style pin striping :wink: 8)
Gadge in the shed... STILLfreezing me bits off...
G40GES
Postby MinorMatt » Sun Dec 11, 2011 12:50 pm
Less I think? :wink:
Postby transitandy » Sun Dec 11, 2011 8:57 pm
Looking forward to seeing the progress on this :) 8) 8)
Postby malta transit » Mon Dec 12, 2011 7:56 pm
transitandy wrote:Looking forward to seeing the progress on this :) 8) 8)
Me too :D
malta transit
Our man in Malta!
Postby oldskooler » Sat Dec 31, 2011 10:39 pm
ive been doing a bit more with this over the xmas hols.
got her on the lift and continued with the stripping.
after some scraping and inspection im well happy with the condition of the underside, few small repairs needed but nothing serious. i dont think the blasting will reveal too many horrors.
im going to remove the battery tray to free up some room and mount the battery in a box behind the cab on the drivers side.
im also going to take out the two steering box mounting plates and replace them with flush plates, got the passenger one out, drivers one is next.
oldskooler
Postby transitandy » Sun Jan 01, 2012 12:18 am
8) 8) 8)
Postby oldskooler » Wed Jan 25, 2012 5:11 am
time for a bit of an update on this one.
i continued with removing the bits that wont be going back!
nasty crack behind the steering box plate indicating that the old girl worked hard in her lifetime!!
no nasty horrors under the plate this side.
next i got the donor in for stripping, oo mk5 just turned 100,000 miles, driving mint but rotten as a pear!!! the late mk5,s really did go badly. i picked this up with a new battery and recent full exhaust for 200 quid.
just for the heck of it while i had the lump and box on the crane i sized it up in the mk1, looks snug enough!
ive had this subframe with twin wheel struts sitting for a while now in planning for an ifs conversion. so the plan was to use this one as the jig.
first i took out the springs and welded a bar in each side to hold the two wishbones in the same ride height position.
i then bolted the subframe into the mk5 shell, got the two front hubs facing dead straight before welding a piece each side of the shock mountings to the spring housings.
so thats the castor and camber locked in position. the flat mounting face of the subframe sits level in the mk5 so in theory if i get it sitting level in the mk1 also my castor and camber should be pretty close to spot on,....well thats the plan anyway!!
next i chopped out the top mount turrets from the mk5. i got a loan of a plasma cutter form a guy at work which shuld be a huge help, it certainly made short work of the turrets!!
i retired the mk5 for the moment till i need to rob some more bits from it as i go along!!
so in with mk1 again and beam axle out.
i was well delighted with the condition of the legs after a cleaning where the subframe ill be going.
with a bit of fettling on the lift i leveled the chassis best i could so i could use it as a reference for the subframe.
so after a bit of jostling with jacks and measuring i got the subframe in hopefully the right position. now heres something i wasnt expecting,......when i tried the mk1/mk2 wheel on the mk4/mk5 hub it wouldnt fit. pcd of studs a wee bit wider on ifs hub. will deal with this problem later but just wondered.
as this is a twin wheel and they generally sit a bit higher im hoping to get away without notching the chassis legs as is done with single wheel vans. im figuring the inch or so wont make much difference and will leave a bit more clearance for the engine and box. ive called in the help of a mate who is a whizz at fabrication and welding to give me a hand with this part of the conversion. the second pair of hands makes a huge difference for getting bits into place etc.
this wedge shaped wee level the old man had lying about came in very handy for setting the subframe level to correspond with the overall chassis. i plan to use two wedge shaped mounting sections with captive nuts welded inside to box the chassis down to meet the subframe. should be a good strong job especially as ill not be touching the chassis bar drilling a a pair of holes in the bottom for the front captive nuts to clear.
i got some 60mm x 60 box section with a 3mm wall which shuld do the job.
this as far as we ave got for the moment, one drop bracket cut out and trimmed to fit. there will be lots more measuring and head scratching before the first weld im sure!! :D
oldskooler
Postby montym100 » Wed Jan 25, 2012 12:25 pm
Fantastic project and great to see the pic`s of the build process 8)
montym100
Postby adam 120 ex aa » Wed Jan 25, 2012 2:57 pm
the side pics look like its gota go back a bit more
adam 120 ex aa
Postby transitandy » Wed Jan 25, 2012 7:55 pm
Very nice m8y :)
Postby Luke » Wed Jan 25, 2012 8:02 pm
superb work 8) i might have to copy the subframe mounting idea and alter mine - i've never been 100% happy with it and that looks loads better 8)
