Mk5 Hi-Cube referb (slow progress)
Postby CH1 » Fri Mar 16, 2012 4:34 pm
Going to start work on my mk5 Hi-Cube next week, going to do everything on it, wings, archers, full paint job, full service, (cam belt, oil, filters, antifreeze etc) It started life as a Omega Express Parcel van, then a furniture van, then as a advertising board at a local pub. Its only covered 96,000 miles but with no service history, it has got the sweetest banana engine in that I have ever heard, started up first turn of the engine after it had been stood outside for 2 year 8) tax disc in the window ran out in 2008 so not been on the road for a while. This is going to be a slow progress thread, expecting it finished in July/August this year :D Here are some pictures of how it stands before the work commences :D
Outer sill is surprisingly good :shock:
Rear near side corner is not so good
Same as the inner rear corner
M1 Tyres
Mobile Tyre Fitting Service
Covering the North East
http://www.m1-tyres.co.uk
Currently running:
Mk5 swb 80 with twin SLDs
Mk7 110ps T300 fwd pickup
Mk7 125ps T350 lwb Euro5
CH1
Re: Mk5 Hi-Cube referb (slow progress)
Postby madbri » Fri Mar 16, 2012 5:59 pm
:shock: :shock: im scraping a high cube that looks better :shock: good luck :wink:
madbri
Postby madbri » Fri Mar 16, 2012 6:01 pm
i no it says highcube on the doors but i cant see a small middle section :roll: look like a hightop :roll:
madbri
Postby Backbone of Britain » Fri Mar 16, 2012 6:07 pm
madbri wrote:i no it says highcube on the doors but i cant see a small middle section :roll: look like a hightop :roll:
Look carefully just before the front of the rear wheel arch you can see the panel. The other givaways are the rear overhang,bumper end caps and the amber marker lights on the side.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby CH1 » Fri Mar 16, 2012 7:35 pm
:wink:
madbri wrote::shock: :shock: im scraping a high cube that looks better :shock: good luck :wink:
The pictures make it look better than it really is :lol: , but I like a challenge and its a mk5 so its worth saving 8)
M1 Tyres
Currently running:
CH1
Postby madbri » Fri Mar 16, 2012 7:55 pm
:? mines got the same but a 3rd pannel on the side :roll:
madbri
Postby transitandy » Fri Mar 16, 2012 11:39 pm
Nice one for saving her :)
Postby CH1 » Tue Mar 27, 2012 8:14 pm
Got some work done on it this last week..........
Advertising boards off
Rear archers are good :D
sign writing off
Wings off
This could have been better :lol: :roll:
I dont know what this is about :? :?
Will get some more done this week inbetween work :D
M1 Tyres
Currently running:
CH1
Postby CH1 » Tue Mar 27, 2012 8:17 pm
Also what would be the best way to fill these bolt holes in once I have taken the wood off? Thought about weld but wont that distort the body and make it all wrinkly :?:
M1 Tyres
Currently running:
CH1
Postby gravelrash2004 » Tue Mar 27, 2012 10:24 pm
if you dont want to weld. treat the holes with your favourite metal sealer, then bond some small pieces of suitably treated metal to the inside of the van, then fill the holes and fill
or fibreglass from behind
or
alternatively you could braze the holes, this way there will be no noticable distortion to the panelwork
My Projects
150S :- DOHC 2.0 EFI (115PS), Ratio: 5.14
viewtopic.php?f=27&t=66682&start=15
viewtopic.php?f=27&t=97579&p=829640#p829640
gravelrash2004
Postby turbotom » Fri Mar 30, 2012 5:31 pm
i would weld them if i was doing it. squash some copper tube and get someone to hold it the other side for you while you weld them up. just do a bit at a time and it wont distort.
turbotom
