Started to tidy the underside up!
Postby ajpmsport » Wed Mar 21, 2012 10:07 pm
Well MOT time again and i keep promising myself to do something with the undercarraige of my van. Rust is creeping through and before you know it there will be holes. Ford seemed to do a good job with stone chip coating but not so good with the painted bits.
I cut out the grot on the inner wings and repaired, and done the two front wheel arches. Then it will be the rear two wheel arches. Then the bit in the middle. I was pleased with the results so far, What do you reckon ?
ajpmsport
Re: Started to tidy the underside up!
Postby Beegly » Wed Mar 21, 2012 10:20 pm
good job, i need to do something similar, atm i give it a coat of underseal once a year
Mondeo 130 TDCI - personal use
30t mobile crane - for work
2004 T280 125 TDCI, 183,000 miles. sold
'96 Citroën ax, 58ps. saved me over £1500 in diesel. SOLD, replaced with
2001 Citroen saxo 1.5 d
Beegly
Postby ajpmsport » Thu Mar 22, 2012 9:44 pm
Back done, and a bit of its belly. Now run out of jollop. Will get some more just to finish off.
ajpmsport
Postby ajpmsport » Sun Mar 25, 2012 8:43 pm
A bit more done. This rate the whole van will be black. :!:
ajpmsport
Postby stephenferguson » Sun Mar 25, 2012 9:06 pm
GOOD JOB, Thats what i need to do next, you just got it on axle stands? i got a full tin of hammerite satin black. What you rubbing down with, wire brush?
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby ajpmsport » Sun Mar 25, 2012 9:28 pm
stephenferguson wrote:GOOD JOB, Thats what i need to do next, you just got it on axle stands? i got a full tin of hammerite satin black. What you rubbing down with, wire brush?
Yep, jacked the back up and put the stands under the axle. Knotted wire brush in a grinder, then jenolite , then stone chip protection in places, then sprayed it.( Masked off the rubber hoses first). I used rustoleum, realy surprised the way its turned out. Im thinking about doing inside the box sections with something. Waxoil would be best but expensive. I`m wondering about old engine oil and something mixed and sprayed inside. ?
ajpmsport
Postby slickmouse » Sun Mar 25, 2012 11:20 pm
Old engine oil as far as i remember is not good, has water and other additives which can cause rust
Lovely job by the way
slickmouse
Postby turbotom » Mon Mar 26, 2012 9:38 am
slickmouse wrote:Old engine oil as far as i remember is not good, has water and other additives which can cause rust
old oil wont cause rust at all. we used to use it all the time on the bright steel work when i worked on the farm. does a great job of protecting things. not so great on cars as water washes it off after a while but better than nothing.
turbotom
Postby transitandy » Mon Mar 26, 2012 6:53 pm
Very nice work m8y :)
Postby ajpmsport » Thu Mar 29, 2012 9:51 pm
ajpmsport
progress report
Postby ajpmsport » Mon Aug 13, 2012 11:18 pm
The crew van is ideal for a service barge and to travel in ..........
BUT to sleep in it`s a bit more difficult................Cuddle up to a few tyres..........
Ok for a one night race weekend. With the bulk head in you have to keep walking around the van.
I wanted to remove the bulk head and put a sliding door in it`s place but this is the main structure for the cupboards and shelves. The charging system is not working to well either.So i took the whole lot out.
We wanted to use the van the weekend just gone so i managed to insulate the floor and board it and make it a bit more comfy. Put the leisure batteries in tempory just to have some lights up.
I fitted an awning rail and awning and was really surprised how well it worked. No rain but was really windy Saturday morning to give it a good test. You can buy a bedroom which zips into the side, so now i know the awning works thats on the list aswell. Just keep on plugging away at the rest of it now. :wink:
Mum, Dad and my boys.
By the way if anyone is interested in the side windows i will be replacing them for bonded ones at some point (the slidy window is cracked though).
ajpmsport
Postby frank133 » Tue Aug 14, 2012 8:38 pm
Looks good mate,one day mine should look as good underneath :(
We have repaired the front inner wings,and fitted new front wings,
The rear inner wings are shot,the outer wings are solid.
A bit of rot on the rear box section,
When we get this last bit of welding done,we will blast the whole bottom with under seal
I think the underneath should be as clean as the top for the m.o.t.
even tho no,one sees it unless you run over some,one :) .
frank133
Postby AlanN » Wed Aug 15, 2012 12:14 pm
like 8)
Postby noah » Mon Sep 03, 2012 11:02 pm
nice use for the van
noah
Postby chris72a » Tue Sep 04, 2012 9:42 am
Nice mate what did you use for those single beds, do they fold up against the side, wanna do something like this in my van but haven't worked out what to do yet, got a race meet comin up in 2 weeks and plan to sleep in van so wanna sort before then.
Cheers
Chris.
chris72a
