by camper extraudinair » Sun Aug 26, 2012 5:28 pm
Hi Transit lovers
Just a little more info afore i go.
A so called friend of mine in the dim & distant past had a
problem with his starter motor in a very busy service
station on the edge of the new forest,
He pulled into the service station between the two rows
of pumps & proceeded to fill his fuel tanks on both sides
of his american camper,
He paid for his fuel got in to start his engine but the
engine would not crank it over.
The starter motor had packed up,
He turned the key while i hit the starter but to no avail,
by this time the que was heading back to the motorway
as he was taking up six fuel pumps, so i towed his six &
a half ton camper to a out of the way with a 1.6 escort,
We had to remove it & take it to a man i know in surbiton
on the a3 near london, i phoned him on the way to make
sure he would be able to help,
He sorted the starter & we hoofed it back to the new
forest fitted it and drove home,
Because of this experience i thought a starting handle
if one could start a 7.2 litre engine on such a device,
Would have saved a lot of hassle.
So i decided to fit one to mine to see if it would work.
I forgot to mention the reason we could not tow or push
start it was because it was automatic transmission,
I aquired several starting handles & dogs that is the bit
that fits on the crankshaft of the engine,
I had to lengthen the handle to make it reach the crank
& also lengthen it on the stroke to give it more leverage.
My engine is only 5.2 litre so i welded the dog on to the
crankshaft bolt so the engine was just before top dead
centre & the handle was at twenty five minutes to twelve.
I was ecstatic when i cranked it for the first time & it
Burst into life.
I imediatly pnoned a friend because that what u do in
a moment of exileration & asked because he is into
v8 engines who has got a v8 engine with a starting
handle, He replied no one i said you do now,
