Hi J.C. hope you & the gang are all good, took Eve for m o t on the 1st of May ? passed with a few
adviso's one of them was the larger tyres had touched the arch on the odd occation, so when i got
back to the ranch i set about flaring the wheel arches, i had asked a so called friend of mine if he
would do it for me over the last couple of months but to no avail, so armed with a club hammer
& heave dolly i went to work, after smashing it for about twenty minitutes a side i then changed
to a smaller hammer & dolly & spent half an hour getting it into a reasonable shape, i then got a
length of stainless steel bundy piping & cut a slot in it with an angle grinder, bent it to shape as
i happered it over the sharp edge & welded it in position, as can be seen in the photo's, i then
filled sanded & primed the arches to be finished at a later date when i can find someone reliable
to paint them for me, also while i have the motor in the air, i have decided to fit larger disc's on
the front axcle ? not that it needs them but the ones on there were a tad small for the calipers,
best wishes to all Raymondo.
ps here is if i can manage it some pics.
