The van is a fairly tidy SWB with a factory Pinto engine and factory bulkhead.
Pinto Bill has owned the van since it was three years old and maintained it very well, but as with all Transits, there comes a time when a decision has to be made to tackle the 'tin worm' and provide a good few years more service.
Pinto Bill came to us to purchase the repair panels needed for his van and offered us the opportunity to carry out the refurbishment on his behalf. He has agreed that the progress report be posted on the Forum as an inspiration to others contemplating a rebuild.
Although we have a fully equipt workshop available to us, all the work you will see posted on this thread could be easily carried out with minimum tooling, most of which is readily available though a variety of outlets and of course eBay.
I will endeavor to provide as much information as to the procedures used as is possible in the hope that this information will be useful to others.
Firstly the rear wheel arch was tackled,
As you can see, the rear wheel arch was trimmed to fit the replacement panel inside the rear quarter, some repairs were necessary to the inner arch. The inner arch is not available for the SWB model, we find using parts of an outer wheel arch panel from the opposite side, with slight adjustment, works well,
In a case such as this, the rear lower corner normally needs some amount of work, while the outer wheel arch panel includes some of the rear lower corner, part of this panel needed to be fabricated,
As you can see, the outer wheel arch panel has been fitted behind the rear quarter panel, the rear lower corner repair being 'joggled' so as to step into the adjoining parts, minimising the repair 'lines'.
The panels are held in place with self tapping screws while placement is confirmed.
Once we were happy with the fit of the outer panels, these were unscrewed and work started on the inner rear lower corner area.
