1977 mk1 aussie transit tray
Postby dob077 » Fri Jan 19, 2007 12:22 pm
hi every one,i have a 73 van for 15 years as my work van,but to much rust now retired to back yard,my current project is my 77 tray which ive had about 4 years.removed every bolt on panel and resprayed,rust repair in floor(minor),today in 40 degree heat welded side rails on tray ready to replace wooden floor.it has a 250ci ford motor and a 3 speed floor shift manual which is all original here in australia.i replaced the front discs and calipers with a 1980 ford sedan(bolt straight on the same stub axels as the english version)replaced the twin wheel 5.22 ratio rear ass with a 1980 ford 2.78 ratio rear ass.the van drives very well sitting on about 1800 rpm doing 100 kph(60 mph).i am learning how to put photos on the forum so keep looking.this is a very good and informative forum.ken
dob077
Postby madmark » Fri Jan 19, 2007 12:24 pm
wow ken you have been working hard!
rust i didnt think you boys had much of that overthere! :?
Postby FredTransit » Fri Jan 19, 2007 3:35 pm
Is a tray a flatbed or pickup then?
FredTransit
Mk2 Trannyist
Postby Granadadriver » Fri Jan 19, 2007 5:13 pm
FredTransit wrote:Is a tray a flatbed or pickup then?
Think it's flatbed! :? Pickups are commonly called "utes" down under!
Granadadriver
Postby stevew » Fri Jan 19, 2007 5:37 pm
Isn't a tray where you have one large flat surface above the rear wheels, typically with no sides. They're really common over in Oz. But not in MK1 transit form! :wink:
Steve
EDIT: maybe they do have sides! You get the idea. :roll:
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby Sundowner » Fri Jan 19, 2007 9:51 pm
Hey dob077 nice to have some more aussie backup, seems that alot of aussie transit owners come from mexico
The front brake conversion you have is it a Rod Shop kit that runs Falcon discs and holden calipers?
If you wish to convert to a 4 speed look around for a 250ci cortina box as the shifter is in the correct spot if you use a falcon box you will need to cut a new shifter hole
Sundowner
Postby zoz from oz » Sat Jan 20, 2007 12:55 am
stevew wrote:Isn't a tray where you have one large flat surface above the rear wheels, typically with no sides. They're really common over in Oz. But not in MK1 transit form! :wink:
Steve
EDIT: maybe they do have sides! You get the idea. :roll: A ute can be both panels and dropside back end, but the dropside is commonly called a one tonner.
Whats this wire do?
zoz from oz
77 tray
Postby dob077 » Sat Jan 20, 2007 11:20 am
over here in australia we call a flat bed a tray top,on my compliance plate it is g.v.w-3236 kg in weight.it is a long wheel base model and used to be a tip top bread delivery van here in mildura.the front calipers are off a xd falcon and bolt straight on.the only thing to do is put a 3mm washer in between caliper and stub where caliper bolts on.thanks for info on 4 speed but i might stick with 3 speed...ken
dob077
up-date 77 ausie tray
Postby dob077 » Tue Jan 23, 2007 12:01 pm
the last couple of days fitted new tail lights,re-fit front indicators,head lights,fuel tank(cleaned and painted) rear shocks,front grill.a bit of a problem with electrical which i will fix.put some fuel in tank and drove it to the local welder mate to get some rust patches in floor pan done.the van went well ,i got some looks from people because i drove it with no windscreen,doors,back window and only one seat including seat belt.i am making a new head lining at home on the sowing machine then i will put windows in and doors on,then its time for rego----cant wait---.will post photos soon...ken
dob077
Postby Sundowner » Wed Jan 24, 2007 9:12 am
Are you sure they're off an XD i cant see how they would bolt straight on
considering that they bolt up in a completely different way and i also know transit calipers fit cortinas and falcon dont i know HQ holden calipers bolt on the same as the transit and cortina because i have a set on my cortina
Sundowner
77 front discs
Postby dob077 » Thu Jan 25, 2007 12:37 pm
hi sundowner,i appologise they are ford vented discs-holden calipers-ford pads.one day i will try to adapt original transit twin piston calipers onto the falcon discs or have you tried this...ken
dob077
Postby Sundowner » Thu Jan 25, 2007 11:40 pm
If you have the holden calipers on keep them on they are a far better caliper than the transit 2 piston unit with more than twice the pad area and you can rebuild both calipers for less than you can buy 1 piston in the transit calipers
I have 4 piston transit calipers and vented discs on my van the discs is the same width as the falcon discs (24mm) but is 20mm smaller in dia over the falcon discs so the transit caliper wont fit the falc disc
Stick with what you got its a good set up
This is a falcon disc and WB holden caliper set up on a TE cortina
Transit Solid discs and 2 piston caliper
Transit vented disc and 4 piston caliper
Sundowner
