Robs Green Meanie !!!
Re: Robs Green Meanie !!!
Postby robbie.cee » Sun May 06, 2018 7:38 pm
robbie.cee wrote:Well visor barely flinched to and from clackton...
Way up van ran so sweet couldnt believe it... more vacuum than I've ever seen and dudnt miss a beat no smell of over fuelling in cab too!!! Tonnes of power to play with and possibly quieter and more deeper note...
Way back idle was stuck at 2-2.5k ish?!? Lumpy and not much vac registering on gauge...
Got back ok but on inspection the idle adjustment grub screw has somehow found its way further in and the lock nut was free to spin....
Ergo i figure due to throttle not actually shutting there wasn't enough vac to suck the boost valve shut
Hence absolute stinky fumey journey home bogging and generally crap compared to this morning ...
Find out tomo if made any difference just shutting throttle back down to acceptable idle !?
Sent from my SM-G920F using Tapatalk
Visor fitted ImageImage
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun May 06, 2018 7:40 pm
Ford on the fairway. Clackton Essex . Meet at golf club funnily enough.
Great to catch up with Grimly Wronghole Tony Allen and AlanN.
Also few folks from the Facebook clan !!
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Wed May 23, 2018 11:00 am
Great little stand we had at Clacton
Postby robbie.cee » Sat May 26, 2018 3:52 pm
So latest update
Maf wire broken..located and re soldered...touch wood all well...
New (to me) Di 67litre fuel tank just modded the sender plate to accommodate 20mm fuel take off...
Next up retro fit the tank.. as currently only have 45l tank...to be done soon ish...
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Sun May 27, 2018 12:44 am
Why are you going up to 20mm Rob, isnt the usual only 8mm feed on the Cossie
Postby robbie.cee » Sun May 27, 2018 1:29 pm
Nah the bottom fed pipe is 20mm into filter and then pump poss lower dia via banjos to engine.
AlanN wrote:Why are you going up to 20mm Rob, isnt the usual only 8mm feed on the Cossie
Had
MAKE IT FIT
robbie.cee
Postby ned » Sun May 27, 2018 1:45 pm
Lovely van you have there Mr Cee Sir 8) can I ask what width are your Weller wheels :?: N
03 transit 125t280 2.0 tdci swb executive college blue 92 crewcab. Built in Belgium so deserves lots of love. 220,000 miles on the clock.
Instructions for use. fill with fuel. start engine. drive like a t#@t.
ned
Postby robbie.cee » Mon Jun 11, 2018 11:11 am
7j mate x 16 and the tire rubs on sld but I'm gonna take hammer to that!
Had
MAKE IT FIT
robbie.cee
Postby ned » Mon Jun 11, 2018 12:29 pm
Ah no wonder they look OK on the arches mine at 8j and stick out about 30mm, arch extensions needed. N
ned
Postby robbie.cee » Wed Jun 27, 2018 11:19 am
So possible breakthru ... today got multi meter out decided ill investigate the gas sensor wiring ... well Yes its there but.....
It defo does not go to the corresponding pins on ecu! Pin 29 &39 are inputs from gas sensors... both have 2inch of wire going no where fast....
Todays job will be rewire that! May save a load of fuel!!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu Jun 28, 2018 10:33 pm
So got the 2 hego (lamda) sensors wired up. Poss in limp mode now .
Had to resolder a wire on maf ((again)) as was not revving up properly. Didnt wanna upset neighbour again so test deive soon see how she runs and if she will go over 3k !
Promising tho and easily recersable if all goes to pot.
Hopeing if sucessful will run better and give better economy too!
Watch this space...
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Thu Jun 28, 2018 10:54 pm
Result poss may just have to earth pin 49 looking at schematics on tinterweb! Find out tomo
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Jul 01, 2018 8:44 pm
Just re earthed said pin so cannot wait to find out result!!
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Jul 01, 2018 9:24 pm
Are you sure yours aren't also 7j because you wouldnt be able to open side door with 8inch wide wheels im sure and mins are also 30mm ish from edges! Well now technically 8mm due to stick on lip extensions
ned wrote:Ah no wonder they look OK on the arches mine at 8j and stick out about 30mm, arch extensions needed. N
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Thu Jul 05, 2018 8:16 pm
Well, how did it go!
