Robs Green Meanie !!!
Re: Robs Green Meanie !!!
Postby robbie.cee » Fri Jul 06, 2018 10:19 pm
Still not driven it since or even started it. 11hr days plus 2 more welding Nicks Relfs van x 5 days im so busy and now to top it off have stomach cramps all afternoon and still now so dunno what tomorrow will bring....couldn't do more than 2 plates today felt so crap had to come home n crash out.
Got welder back to do exhausts for tomo evening meet in Kent but at this rate wont be going or welding !
Still excited to see what effect the rewire did!
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Jul 06, 2018 10:20 pm
Luke or pete or anyone who has tapped into lambda probes for a fuel ratio meter am i right in thinking i should see no more than 1v on the signal to meter/ecu????
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Jul 08, 2018 5:41 pm
Well i am pleased to report back the van runs sweet as no back firing or missing on the short jaunt round the block twice and althought didnt wanna open her right up and attract attention she certainly didn't mind revving up past 3k so defo not in limp mode for sure !
Exhaust now re welded one front gasket had failed so i just welded over the gap, ill not be removing it in a hurry so no dramas there. Few small holes in centre boxes and few tiny blows in joints re done now no rasp what so ever which is also cool!
Nice long journey will tell all and if economy has improved and only other big jobs left on cards is swap shocks n springs for the new fronts i have and anti tramp bars still yet to be fitted too!!!
Oh and fuel tank.. got a 67l di one and just need to do that too!!!
Had
MAKE IT FIT
robbie.cee
Postby RustWidow » Sun Jul 08, 2018 10:57 pm
robbie.cee wrote:Well i am pleased to report back the van runs sweet as no back firing or missing on the short jaunt round the block twice and althought didnt wanna open her right up and attract attention she certainly didn't mind revving up past 3k so defo not in limp mode for sure !
Well done mate, I bet you’re well happy :)
RustWidow
Postby Luke » Sun Jul 08, 2018 11:24 pm
robbie.cee wrote:Luke or pete or anyone who has tapped into lambda probes for a fuel ratio meter am i right in thinking i should see no more than 1v on the signal to meter/ecu????
sorry rob just read this - i think the problem with my afr meter was i used a standard lambda sensor - i think you need one matched to the gauge - thats what im doing next ive got another boss to weld into my exhaust to keep it totally separate from the ecu one.
Postby robbie.cee » Mon Jul 09, 2018 7:00 am
All good not using afr gauge just unsire of signal from standard lambda probe.
Defo seems to be happy tho so cant wait for a proper long drive to test soon. Poss weds.
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Jul 14, 2018 1:05 am
Glad to report back recent drive to kent and back was spot on didnt miss a beat. Possibly slightly down on power tho or could be my imagination.
Defo much smoother tho and now rewelded exhaust sounds better and doesnt stink in cab as bad now.
Would go as far as saying some slight increase in economy but return trip home was fun.
No bogging at lights too now i must add so the hunting has gone!
Must do brakes next job too gettin bit spongy!
Thats all for now !
Had
MAKE IT FIT
robbie.cee
Postby Luke » Sat Jul 14, 2018 9:11 am
if your doing disks and pads Rob you can fit the 6 stud caliper carriers to your hubs (use same calipers) then you can fit new bigger 6 stud 190 disks and pads - good upgrade for a van like yours :D
Postby RustWidow » Sat Jul 14, 2018 9:47 am
Luke wrote:if your doing disks and pads Rob you can fit the 6 stud caliper carriers to your hubs (use same calipers) then you can fit new bigger 6 stud 190 disks and pads - good upgrade for a van like yours :D
Yeah, I think I would upgrade the brakes if it were me... speed and power are great but you gotta be able to stop! Lol. Great news rob, glad you’re getting her sorted
RustWidow
Postby robbie.cee » Mon Jul 16, 2018 7:31 pm
Today i just added 12v to pin 6 of ecu to tell it the air con that i dont have is 'on' lol. Should further help idle revs .
Defo purrs once again now that fekin huge blow is welded up !
Poss down a smidge now the lambda probes are wired up but guess should see proportional return in economy (if i can keep under 3k rpm!).
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Mon Aug 06, 2018 3:54 pm
Just got back from weekend in Ipswich at the festival of wheels.
Towed the lil caravan up and had back of van packed out with mobile dj set up so properly loaded up.
Got there on just over half tank and got back on tad under half.
Reckon now the hego sensors are wired up they seem to be making a return on economy so always a bonus!
Had
MAKE IT FIT
robbie.cee
Postby RustWidow » Mon Aug 06, 2018 8:11 pm
Congrats on helping the stand win!
RustWidow
Postby robbie.cee » Mon Aug 06, 2018 9:30 pm
Not surenif we won anything but the djing seemed to get a good reception from the whole field !!!
Had
MAKE IT FIT
robbie.cee
Postby RustWidow » Mon Aug 06, 2018 9:43 pm
Excellent, what more can you ask for? We are going to have to come next year....
RustWidow
Postby robbie.cee » Fri Aug 24, 2018 12:09 am
Latest update changed the rear left cylinder in brakes other day. Actually surprised how easy it was.... find out soon if i did it right lol!
Springs n shocks up front next mot.soon!!
Had
MAKE IT FIT
robbie.cee
cron
