mk 7 work/weekend van build
Re: mk 7 work/weekend van build
Postby dodgy01 » Sun Dec 07, 2014 4:32 pm
so the questions begin
i want to add a second battery for work lights
i have a spare unit from a 2009 van that had 2 batteries on it
how do i wire up the relay so when the van is running both batteries charge up together
also i have the motors and harness from a van with elec windows that i want to fit
do i need any relays or extra wires to be run or will it plug and play
i also want to add the lower spot lights
i do have these and i also have a spare headlight switch that comes from a van with lower spot lights what else will i need
thanks
dodgy01
Postby dodgy01 » Mon Dec 08, 2014 7:51 pm
ok plan number 2
I've just put a deposit on this
I've got to go to carlisle saturday to collect it
its done 112k and I've just paid £1,700 for it
body work needs a tidy up
dodgy01
Postby karl » Mon Dec 08, 2014 7:53 pm
so you have both ?
karl
Tranny Lover!!!
Postby dodgy01 » Mon Dec 08, 2014 8:00 pm
as above the first one got wrote off the morning that i was due to collect it
so i have now purchased the second one
dodgy01
Postby paul2012 » Mon Dec 08, 2014 8:16 pm
Ford Transit T280 2.2 85sp - very short MOT (3rd March)
Looks tidy, I would double check N/S front sill & forward rear arch at the bottom. :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby dodgy01 » Mon Dec 08, 2014 9:04 pm
the mot does not bother me ( i won't tell you why :wink: )
why the n/s sill?
dodgy01
Postby karl » Mon Dec 08, 2014 9:07 pm
it must be showing up on the data base as advisorys ,@at paul am i correct :?: :(
karl
Tranny Lover!!!
Postby dodgy01 » Mon Dec 08, 2014 9:12 pm
my previous vans
ill see if i can find them both
viewtopic.php?f=27&t=87849
heres the other one
viewtopic.php?f=27&t=56371
dodgy01
Postby Punto443 » Mon Dec 08, 2014 9:40 pm
Of your still interested in converting to twin batteries
viewtopic.php?f=18&t=89599
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby dodgy01 » Mon Dec 08, 2014 9:53 pm
thanks ill refer back to it when i get the van
dodgy01
Postby dodgy01 » Fri Dec 12, 2014 6:49 pm
well I'm off early in the morning to pick up the new van
ill post some pic on sunday
dodgy01
Postby dodgy01 » Sun Dec 14, 2014 5:09 pm
well after a 500 mile drive yesterday it never missed a beat and drove better than a lot of lower mileage vans i get in at work
it does have a few issues tho
ill put them here and in mk7
when it starts from cold the throttle does nothing for about 20 seconds then its fine all day?
i have the cog with a ! in the middle on all the time .ill plug it in at work tomorrow to see if it tells me any thing
also the side loading door won't open ,it sounds like its un locking but the handles do nothing ? is there a way to open it without damaging the door
I've had a day working on it so it now looks a little better
any help with the above would be amazing please
dodgy01
Postby ake » Sun Dec 14, 2014 5:52 pm
If you look under the bonnet, on the top of the chassis legs, near the front you may find the fog light connectors clipped back to the loom, but if not, fit lights, connect one wire from each to earth, connect other wires together, run round engine bay, and into area behind glove box, then connect into junction box, I'll find out which pin later, that's what I had to do to mine.
The wiring for the switch will already be there :)
Postby dodgy01 » Sun Dec 14, 2014 5:54 pm
paul2012 wrote:Ford Transit T280 2.2 85sp - very short MOT (3rd March)
looks ok the only advises where 2 front tyres
dodgy01
Postby transitandy » Sun Dec 14, 2014 7:42 pm
A nice van m8y well done :)
