mk6 recovery truck progress
Postby bigron1988 » Sun Dec 14, 2014 9:35 pm
here is my mk6 transit recovery truck, i do have a progress thread somewhere but all the pics have gone so thought it would be better just to start a new one
how i first got the truck
back taken off
then went in for a full respray
new sun visor
4+1 rear springs
euro liners
new front bumper and ford badge
then had a recovery truck body made
and windows tinted
hids and led bulbs fitted
and chrome nudge bar
interior carpet
electric windows and electric windows fitted
then had a tow bar fitted
new belt and tensioner
then had the van remaped and put it on my mates dyno to make sure its all good
and a few pics of some of the cars ive moved
then back august time i was driving down the motorway and it got hot all of a sudden then there was a bottom end knock developed turned it of and got a mate to collect me
and the truck has been parked up till yesterday when i decided to see whats what with it
damage on the little end bearing on conrod
this bolt was found in the sump and it looks like its a bolt that holds the rocker arms on , but there are none missing so i think its had some work before i got it and someone has left a bolt loose in the engine and its only just become a problem
we also found that that radiator has ballooned up and has started leaking so we think thats why it has got hot and then caused the engine to run hot and damaged the little end bearing, the block is all good as is the crank and pistons, im not 100% happy with the state of the conrod that the bearing let go on as it has a few scores on so will take it to my engineer and see what he says , there is also score marks on the cam journal on the head so it might need a new head to,so while its apart i might as re build the full lot, shopping list so far is
big end bearings
little end bearings
main bearings
crank seals
head bolts
head gasket
full chain and tensioner kit
full gasket set
piston rings
head will be pressure checked if the damage is ok and will have a skim and rebuilt with new seals and valves re lapped back in
block will have a hone and a skim to make sure its all straight
clutch was checked as i was going to fit a new one too but it had a new one just before i bought it (have reciept) and its like brand new still, (its been converted to single mass already too) but the ring gear is a little warn so will replace that
will also need radiator and going to put a water pump and water temp sensor on it as ive replaced the thermostat so thats all water system sorted , the plan was to fix it up then sell it as i dont use it enough and get a trailer but i just cant seam to want to get rid especially after spending all this money on it
bigron1988
Re: mk6 recovery truck progress
Postby Andy P » Mon Dec 15, 2014 11:54 am
surley after all the work you have put into that truck you cant sell it, I am working on mine all the time and not had to do half of what you have done, I want a set of those wheel trims, where did you get them from ?
and just to say the truck looks the nuts well done
Andy P
Postby BigMonty » Mon Dec 15, 2014 8:40 pm
:lol: My BJT w*** phone took 3 attempts to load all these pics.
Looks like a new truck, well impressed 8) Hopefully it will go like one too.
BigMonty
Postby bigron1988 » Tue Dec 16, 2014 8:20 pm
cheers guys, i bought the trims from ebay a few years back , just had a look and there are none listed atm,
i dont want to sell it but in the last year ive prob done 1500 miles in it , so makes sense to buy a trailer as i dont need to tax/mot/insure another vehicle then
bigron1988
Postby bigron1988 » Thu Jan 08, 2015 10:11 pm
been busy buying lots of new parts ,
rear prob bearing
glow plugs
water pump
gearbox seals
gearbox oil
engine oil and filter
water temp sensor
timing chain kit with pullys
front timing chain cover
radiator
clutch fork
new clutch
release bearing
clutch and flywheel bolts
new solid flywheel
block back from having a skim, hone and a proper clean
cylinder head been skimmed, pressure checked, valves cleaned and re lapped in and had a proper clean
new no4 piston and rod
new piston rings for the other 3
big end and main bearings
head gasket, headbolts and gasket kit
crank seals and cylinder head gaskets
all ready to be assembled
bigron1988
Postby Andy P » Sun Jan 18, 2015 11:19 am
any more news on how its going ?
Andy P
Postby transitandy » Sun Jan 18, 2015 1:22 pm
Hell of a thread m8y :)
Its a lovely looking truck as well 8) 8) 8)
Postby dirtydog » Mon Jan 19, 2015 9:19 am
That's a lot of new parts :shock:
dirtydog
Postby RustWidow » Mon Jan 19, 2015 9:50 pm
Wow, can't wait til you fit all of them parts! Lovely shiny new engine bits, love em! Well done
RustWidow
Postby bigron1988 » Wed Jan 28, 2015 9:44 pm
well its been a few late nights but its all back up and running done 120 miles in it now with a oil change done ,
forgot to take a pic of new clutch fitted
took 2 hours to get it to start it was a right twat
then when we did get it started the rear water pipe was leaking from the bracket so had to go scrappy and get another one
bigron1988
Postby Andy P » Thu Jan 29, 2015 12:06 am
wicked glad to see it back on the road, you can not be serious about selling it now [ well not for a few years] the amount of work gone into this, WELL DONE.
Andy P
Postby RustWidow » Thu Jan 29, 2015 9:58 pm
Great job, well done
RustWidow
Postby BabyDontYurtMe » Thu Jan 29, 2015 11:12 pm
Outstanding work, and great catalogue of pics - cheers for taking them its nice to see engine work illustrated well
QUESTIONS!
1. Engine stand/hoist - do you have a recommendation? Need to find one that is reasonably priced and that I can use on a driveway/home garage.
2. Can I be cheeky and ask for a rough cost of all the parts you bought for the rebuild? Is everything you replaced necessary for a rebuild or just because you wanted to make sure it was good?
3. How did you clean the inside of the block/crank/pistons? Engine degreaser or something else?
4. Any estimation on time spent doing all of this?
Sorry for all the qs mate, nice job though that van looks awesome.
Completed the Mongolia Charity Rally 2015 with a beautiful Mk6 LWB high roof Transit.
We loved it so much, we have just purchased a Mk7 LWB high roof Transit to do some staycationing!
BabyDontYurtMe
Postby garry_noble » Mon Feb 09, 2015 12:02 am
Where did you get the body made and how much I've been looking for something similar to yours need to have nice angle for low cars how does urs do with low cars
garry_noble
Postby bigron1988 » Mon Feb 09, 2015 10:09 pm
garry_noble wrote:Where did you get the body made and how much I've been looking for something similar to yours need to have nice angle for low cars how does urs do with low cars
There was a advert on eBay for the fella making them he's over in York there are none on there atm but he did comment on the transit Facebook page if your on there
bigron1988
