mrepson wrote:got a brand new glass nearside headlight, £10 if you want it, am in blackpool,got a few scrap turbo smileys,if you need any parts,
truckcreation wrote:Hi mate looks like one of our trucks built many years ago !! Has it pro on engine???
bringmycar wrote:Bought the fuel tank today and apparently its the later 98 model tank that fits and not the 94 one??
dieselhead123 wrote:bringmycar wrote:Bought the fuel tank today and apparently its the later 98 model tank that fits and not the 94 one??
Hi there, you might need to swap the fuel sender with the original one. The later senders, (used with the later electronic drive speedo clusters), are wired in 'reverse'. As a consequence the fuel gauge will read in reverse, full = empty, empty = full.
If your cluster is the early cable drive speedo type then you need the sender with a part number starting 95VB, later one, (to suit electronic speedo cluster), is 97VB.
