Lucifer in progress
Lucifer in progress
Postby ned » Fri Mar 11, 2016 2:19 pm
So I thought maybe I should start a progress report for "nedforceone" or the "bitch" as I sometimes call it.
I will put some pictures on of how it looks now and what I have already done plus what I plan to do.
All opinions and advice welcome many thanks. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: nedforceone in progress
Postby ned » Fri Mar 11, 2016 2:31 pm
Some little mods.
ned
Postby derv23 » Fri Mar 11, 2016 5:34 pm
Nice mods. Looks 8)
MK5 Tourneo.
derv23
Postby ned » Fri Mar 11, 2016 6:26 pm
Cheers mate,
Started subtle mods, try to do something different.
Side window from mk5 doesn't fit flush but I have plans for that.
Rear corner upper bumper from a van with normal doors so been bodged till I can find the right one.
Drivers door needs raising up as its rubbing on door sill.
Dented sill underneath hmmm has this been dropped of a high kerb same on other side.
. N
ned
Postby ned » Fri Mar 11, 2016 6:49 pm
Plans in no particular order:
Fix all dents, rust and scratches.
Weld steel to the sides where its recessed to make a flush look (window will then fit flush).
Fit side window to sld.
Re-spray the van in collage blue 92.
Fix trim pieces.
Build and fit side exhaust one each side.
Alloy wheels? Possibly at some point.
Airbrush company details.
Inside plans:
change rear seats for a bench of 3 instead of 2 from mk7 and 1 from mk5.
Insulate and board the roof and fit roof lining.
Re-board behind rear seats.
Fit a tv and xbox in rear seats (for the kids :D )
Re-trim all seats and door cards.
Fit carpet and line middle walls.
Re-board and rack rear load space for work gear.
Finish moving radio to roof.
Fit reversing camera.
Cant think of anything else yet. N
ned
Postby ned » Mon Mar 14, 2016 7:32 pm
Thought I would tackle some rust in the nice weather, need to buy a welder but which one is easiest to use. N
ned
Postby dantranvan » Mon Mar 14, 2016 8:27 pm
Were headlight washer jets an option on the transit or you stolen them from another model?
Like your idea of simple and subtle mods. Same sort of line I'm wanting to go down. OE+ style to make the van that should've come out the factory
dantranvan
Postby ned » Mon Mar 14, 2016 9:12 pm
Head light washer jets were pilfered from a fiat stilo that was going to the scrapyard, I removed the rear wash wipe from the van and used the pipe to link to the jets, they could do with being a bit more powerful but did remove some of the road salt over the winter I was thinking of fitting headlight wipers as well. I am trying to make it different to other vans but not to obvious. N
ned
Postby ned » Fri Jun 03, 2016 1:05 pm
Thought I would update some pictures so far
The surprising find after removing the plastic step covers, very clean for a 13 year old van.
Boarded the roof above the tea seats just needs carpet.
New radio position just need to tidy up the front and carpet the roof lining.
Waiting for the rear camera to fit in the screen where the radio was.
Changed the dash colour from silver to blue.
N
ned
Postby ned » Fri Jun 03, 2016 1:10 pm
Front wing removed not too bad.
New front wing required it show how they rust from behind.
Nice blue dash bits.
N
ned
Postby karl » Fri Jun 03, 2016 1:47 pm
that plastic guard hold all the sh*t in the arch so it rust from inside out
bad design again i alway wash mine out with a very powerful pressure washer :D
karl
Tranny Lover!!!
Postby ned » Fri Jun 03, 2016 1:51 pm
I am going to make some arch covers to stop the crap gettin up there, spent 2 hours cleaning all the little nooks and crannys that store all the sh*t.
Bloody ford designers. N
ned
Postby ned » Thu Dec 29, 2016 5:44 am
Thought I would update this , its been a while, things done since last update,
Yes its not as much as some have done in the same time but hey some times I cant be arsed or have no bloody money :lol: N
ned
Postby bambi mk 1 » Thu Dec 29, 2016 11:51 am
You can hide but you can never run .......................for long Ned :wink: Orange blossom special in the dash :lol:
bambi mk 1
Postby chris72a » Thu Dec 29, 2016 12:05 pm
Nice Ned, I take it you haven't had it resprayed yet? Looks good though :-)
chris72a
