Brains_transit wrote:Paul2012 just fitted a mondeo engine in his mk6 so he might be able to iron out any spare plugs
spudmab wrote:The only part of the loom I'm confused with is the sub loom that plugs in down behind the drivers side headlight, it plugs into the air-con pump, not sure where the other plugs go, can't seem to find any connections around this area
paul2012 wrote:spudmab wrote:The only part of the loom I'm confused with is the sub loom that plugs in down behind the drivers side headlight, it plugs into the air-con pump, not sure where the other plugs go, can't seem to find any connections around this area
Posted info hereviewtopic.php?f=5&t=168460#p1430641
Thanks paul2012 I have just seen, I did notice that you are close to me when I read your build, was thinking it would be handy to get to know you as you seem well clued up on these later vans, I'm more old school Fords and motorbikes,
Just noticed your location. Littleport - You're just down the road from me
spudmab wrote:Just been our and done some work on the inside of the van, replaced the passenger air vent as it was broken, fitted the secondary power socket at the bottom of the dash, wiring was there, socket was missing.
Things are really taking shape now, hopefully be on the road Thursday 24th as insurance should start then. Couldn't get my insurance swapped from my other van as the tourneo comes up as a car, lol, can't work that out but insurance company have transferred my 8 years commercial no claims bonus to the tourneo car insurance.
Still not sure what's causing the battery light but I'm thinking of buying a new voltage regulator and trying that.
Also any one have any suggestions on sorting out a floppy gear leaver, I have check the 10mm bolt at the gear box end and that is tight.
paul2012 wrote:
Transit van is vehicle cat N1 (Light goods vehicle)
Tourneo is vehicle cat M1 (passenger vehicle) same as normal cars & MPV's. Plus you can drive at the normal speed limits set for cars.
& road tax price is different compared to vans
