Transit Smiley TD new Project..
Postby Kev1000s » Tue Jul 19, 2016 9:19 am
Picked this up from HiRoller last week , Drove it home 100miles , Fitted new turbo. About to renew rear crank seal and gasket and fit new clutch that i have.
I have a set of 100ps Injectors to fit when i have mot,d it in August, it is intercooled already ,also have a boost gauge to fit. :D
Ford FDS 2000
52 plate , Smiley 150lwb ,Td,Ex police :)
1996 Smiley 100 ,Td-Intercooled , lowered 50mm,mk6 wheels,lsd 4.11..
Kev1000s
Re: Transit Smiley TD new Project..
Postby transitandy » Tue Jul 19, 2016 11:05 am
Nice project m8y :)
Keep us informed of your progress :wink:
Postby Keef » Tue Jul 19, 2016 11:48 am
That van was a proper bargain at £350. It was so cheap that I nearly bought it myself even though I didn't really need or want it :lol:
Keef
Postby chaslynch » Tue Jul 19, 2016 4:57 pm
That looks like a cracking deal.
Well done
chaslynch
Postby Kev1000s » Mon Jul 25, 2016 11:58 am
Sorted rear crank seal and had a new clutch so fitted that while gearbox out, ordered new sump gasket as it looks iffy at the crank seal housing, going to fit that ,and do oil change.. :D Al
so fitted central locking motors to all doors,will run wires when i get electric windows for it as van has a low spec loom...
Ford FDS 2000
Kev1000s
Postby Kev1000s » Thu Aug 04, 2016 1:42 pm
Few pictures , 100ps injectors now fitted and leak off mod done , need to sort fueling now as abit smokey.... :shock:
Ford FDS 2000
Kev1000s
Postby Kev1000s » Fri Aug 12, 2016 9:58 am
Mot time ,and she failed on abit of welding ( 4 bits ) So out comes the welder... :shock: :twisted:
It goes loads better with the 100ps injectors in (Thinking about sticking 130ps in so might sell the 100ps..!)
Treated it so a few goodies , Matching boost gauge and Exhaust gas temp gauges , Alloy oil catch tank as going to fit different air filter and remove air box, and a alloy boost pipe instead of steel one fitted, and a spare 16inch mk 6 wheel.. :D
Ford FDS 2000
Kev1000s
Postby Kev1000s » Mon Aug 15, 2016 12:31 pm
Mot passed.... :D :D :)
Ford FDS 2000
Kev1000s
Postby Kev1000s » Sat Sep 03, 2016 10:19 am
Bought a few performance bits ..! Pictures added.. :D
Ford FDS 2000
Kev1000s
Postby mrepson » Sat Sep 03, 2016 10:46 pm
whats it like now,with the 130 injectors in,does it pull better :?: is there more smoke,& more poke 8)
mrepson
Postby Kev1000s » Mon Sep 05, 2016 6:50 am
Yes pulls loads better, abit of smoke....!... :)
Ford FDS 2000
Kev1000s
Postby mrepson » Mon Sep 05, 2016 9:36 pm
Kev1000s wrote:Yes pulls loads better, abit of smoke....!... :)
so have you left the pump the same,as when you had the 100ps brown injectors in,or had you,turned the pump down, :?:
mrepson
Postby Kev1000s » Sat Nov 19, 2016 1:45 pm
Got my wellers drilled and a 205-65-16 tyre fitted to rear , going to try it on the front to see if it will go . Have the diesel pump off the van and have a 145 pump to go back on ( not real happy with the old pump ) to see if it makes a difference..
Ford FDS 2000
Kev1000s
Postby Kev1000s » Fri Nov 25, 2016 1:08 pm
Wheels now on tyres 205-65-16 rear and 195-65-16 front. Thinking about painting gloss black or satin black .New 145 diesel pump fitted runs loads better...!
Ford FDS 2000
Kev1000s
Postby Kev1000s » Wed Nov 30, 2016 11:07 am
Just bought this 205 pinto engine out of a transit.....
Ford FDS 2000
Kev1000s
