DodgeRover wrote:Just spotted this megasquirt 3 for sale, nothing to do with me and I don't know the seller but sees reasonable price
http://retrorides.proboards.com/thread/ ... ms3x-cheap
rob1985 wrote:Cracking van mate, just a question about your wheels really, what offset are your front ones? When you said you've redrilled them did you drill for the pcd or the small bolts around the edges? Thanks Rob
rob1985 wrote:Thanks for the info mate, what pcd were they then? 5x165? I've got a mk3 so the rears would fill the arches perfectly! Thanks Rob.
Luke wrote:rob1985 wrote:Thanks for the info mate, what pcd were they then? 5x165? I've got a mk3 so the rears would fill the arches perfectly! Thanks Rob.
if you mean your van is a mk3 then the rear arches are narrower than the mk5 tourneo so the exact same offset wheels might not fit
Sounds like a pain in the arse! Do the wheels have to be redrilled then or can you run them on the landy pcd? Might just get some steels banded.Pocketrocket wrote:Luke wrote:rob1985 wrote:Thanks for the info mate, what pcd were they then? 5x165? I've got a mk3 so the rears would fill the arches perfectly! Thanks Rob.
Good point luke, because of the rolled/wider lip on the mk5s?
May have to go for skinnier tyres to make them stretch under the mk3 arches?
BROWNYS V6 wrote:ive read a few comments on faceache, people just bolting landy wheels on,
Pocketrocket wrote:BROWNYS V6 wrote:ive read a few comments on faceache, people just bolting landy wheels on,
Yeh I've objected a couple of time but you just get shot down and the same replies from the same people of "I've had them on for months with no problems"........Yeh thank god your nowhere near my daughters school incase 1 comes off!
They even give each other tips on how to line the wheel up because the holes arn't in the right place!!
Well it's gotta be safe or it ain't happening!! Thanks for all your replies, I'll have a look for an engineering firm who can drill them for me. Luke, if Pocketrocket (sorry I didn't get your name??) Is running a mk3 rear axle will the offset make a lot of difference on my van as it is a mk3? Cheers guysbambi mk 1 wrote:Pocketrocket wrote:BROWNYS V6 wrote:ive read a few comments on faceache, people just bolting landy wheels on,
https://www.youtube.com/watch?v=mJIn6gMlo6A
