Well, it seems I´ve got bigger problems here..
The van is really not behaving... So its not only the brakes..
I really hope it´s down to poor batteries as the van, before I got it, had not been driving for several months and there was absolutely no power what so ever.
I have cleared all the faults and errors with the IDS and none is staying atm.
But I have some strange behavour, whitch I hope is down to the electrical. The IDS says I have only 10 volts on the batteries... charging seems not to be working and I´ve tried both a charger and a 2 hour drive. Once started it delivers 14 something volts.. and everythings seems fine at first...
But...
The brakes work on/off. They almost for sure don´t work the first time it´s started. The pedal is rock hard. Restart and the brakes work.
The turbo works on/off too... restart and the ok (fault appears on IDS after that)
The powersteering seems to be very heavy and not working properly at idle. If i rev it, then its much better.
I also have a noise from the generator.. well from the rubberband (don´t know the name of it) when the van seems to be underpowered... it´s only when driving though... at idle it sounds like a need engine.
When the power is "ok" it seems to go away..
I also experience the "click click" thing, when your car battery is all gone. The car just wont start, and everything flashes and it won´t start. Think we´ve all tried that in our life with any car... but then I can wait 10 sec. and then it will start... slow but it starts... Damn, it´s not funny.
But to get this startet and to kill all speculations about batteries, I managed to get 2 brand new from Varta (same as fitted) before closing time. Now I just need to get the old ones out and these fitted.. And I then hope that at least some of my problems are gone!!
My mec. has a junkyard nearby and there is a van similiar to mine, so please.. think of parts I need to check, if this is not the answer to anyting...
ps. the vacuum pump seems to be working.. and the brakes are marvelous when working and the turbo too... well, you know... still feels like driving with an ancher thrown... but I´m not going for anything before this is sorted out
