Loots Asbo 130ps
Re: Loots Asbo 130ps
Postby Altransit » Sat Mar 13, 2021 3:36 pm
ned wrote:Has the Glasgow turbo, brum brum see you Jimmy oche aye get ooot the way
It can be hard to pick out the useful stuff from Loots ramblings :lol:
loot wrote:But i fitted the new turbo from mr Andz which was like new compared to mine.
Postby ned » Sat Mar 13, 2021 3:44 pm
:lol: :lol: Good point, I was actually wondering if as I has quit smoking now.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby andz327 » Sat Mar 13, 2021 8:00 pm
loot wrote:Now then, will it fit
Naw thats a rwd unit
Should look like this
Sent from my LG-H870 using Tapatalk
andz327
Postby andz327 » Sat Mar 13, 2021 8:10 pm
Whats all them tools for and why did you take the heater blower intake off , 4 exhaust bolts , 3 manifold bolts, oil pipes bolts and its off, knew i should've dropped it off personally and I'd swaped it when your were in making the coffee
andz327
Postby andz327 » Sat Mar 13, 2021 8:16 pm
bambi mk 1 wrote:
loot wrote:So I think I need this 1
https://www.ebay.co.uk/itm/363035339933
You know thats a fwd cooler Loot don't you :wink:
His van is fwd
andz327
Postby loot » Sat Mar 13, 2021 8:27 pm
Well I've fitted the turbo, there's a bit of smoke when I floor it and there's no boost, I still have an engine warning light on but my quick code reader is in the combo.
I will get ids going and see. 1 thing I will say is that turbo I sent back went like fook. But I have the actuator from it.
Only went to the skip in it so I'll clear code's and get it hot maybe it is clogged from running without the turbo boost.
The turbo is in good nick though so not sure
07 350 170ps
Ids map here
loot
Postby loot » Tue Jan 30, 2024 12:43 am
Van is now tested for another year. They charged 45 quid then said it was class 7 so next year will be 5 quid.
I had to pay for another test.
So it failed on imbalance/ handbrake on drivers side not as good as left side. I bought a new caliper which didn't fix the problem. So having tried various things I decided that the left handbrake was too good. But I swapped both rear calipers complete from forskin and it passed.
07 350 170ps
Ids map here
loot
