Loots Asbo 130ps
Re: Loots Mk7 130ps
Postby loot » Sun Jun 09, 2019 2:05 pm
:lol:
But it's an lx :shock: :lol:
Ids map here
loot
Re: Loots Mk7 130ps
Postby andz327 » Tue Jun 11, 2019 5:07 pm
Used to see a lot of those vans about Glesga think the company was "innserve" , the use long customs noo
How you get on with it ??
ANDZ
andz327
Re: Loots Mk7 130ps
Postby loot » Tue Jun 11, 2019 6:13 pm
Just waiting for some bits, it is at mums so not spending much time on it at the moment. I need the lair sorted so I can fill it with crap and vans :shock:
Still driving red, need to sell it and get asbo outside so I can nip out there and sort it out. Really bad place I live with no outside space in the front and it is a square so I'm there basically in front of next door looking into their living room. :?
Ids map here
loot
Re: Loots Mk7 130ps
Postby andz327 » Fri Jun 14, 2019 1:00 am
2nd hand bcm not do the trick?
ANDZ
andz327
Re: Loots Mk7 130ps
Postby loot » Fri Jun 14, 2019 10:10 am
I've fitted and programmed the bcm all working but not fixed it, i have swapped the wiper stalk to another 1 and that hasn't worked. I have swapped the wiper unit which didn't work on either of them.
I've bypassed the relay and that got the wipers to work which I thought was slowly but could have just been quickly.
So i need to flip r23 and r25 to see if the wiper works slowly. When I flip it down I think that just gives a single wipe doesn't it. I can hear the relay click but no wiper.
The relays switching is done by bcm logical ground to the coil side and all positives are constant ignition live.
I have checked all fuses.
The wiper I took off works fast when powered and slow when powered.
So i an looking so far at a faulty live from relay to motor which I can feed through.
Also the guy has been to an auto spark as there is a thick cable fed through to somewhere and blue crimps at the stalk all bodged up :P
Or the quick answer you probably wanted.
Nope :shock:
:lol:
Bloody Loot :oops:
Ids map here
loot
Re: Loots Mk7 130ps
Postby Airthies » Fri Jun 14, 2019 10:42 am
Loot did you suck and blow the BCM config OR load from a built?
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Loots Mk7 130ps
Postby loot » Fri Jun 14, 2019 1:16 pm
Mr Airthies how very dare you sir :shock: I've never been so insulted in all my life :lol:.
Especially from a fellow engineering type. :|
The latter :wink:
I will be getting to the crux of the problem this week as I'm on my jollies for 7 days. And no I'm not going anywhere nice :lol:
Ids map here
loot
Re: Loots Mk7 130ps
Postby Airthies » Fri Jun 14, 2019 1:29 pm
I trusted you would but as with all things the question does need to be asked to rule out something small that could easily be overlooked.
It does sound like wiring/relay issues then or it could be a second duff BCM from a dodgy source
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Loots Mk7 130ps
Postby loot » Fri Jun 14, 2019 1:47 pm
:lol: the pirate that had a wooden leg a hook for a hand and stuffed parrot adorn his shoulder but leaning to the side looked more than trustworthy to me :lol:
Ids map here
loot
Re: Loots Mk7 130ps
Postby Airthies » Fri Jun 14, 2019 1:57 pm
Ah but you just never know. There's many dubious characters lurking online ready to pass on substandard goods to unsuspectingly trustworthy individuals
But I have every faith in your judgement of upstanding members of the community
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Loots Mk7 130ps
Postby Finn_Timo » Sat Jun 15, 2019 7:51 am
Engine malfunction:
I had MK7 Tourneo with 130PS engine last winter, same info was everytime in speedo when bus was started.
Changed three injectors (one was nearly new), SCV/PRV was changed and still I couldn't get learns done.
Everyone I spoke to told that it can't be CR pump as they very occasionally fail on these... Well, one day I changed and hey presto, learns went thru!
So start looking for good 2nd hand CR pump
BR, Timo
Ford Tourneo SWB '07 with 130HP, 9 seater bus made by PROFILE
Tonic
Also there are 1- 3 other MK6's, stock changes...
Finn_Timo
Re: Loots Mk7 130ps
Postby loot » Sat Jun 15, 2019 8:38 am
I think I'm getting 4 injectors and a fuel pump. I didn't plan on it being that but I expect I'll be changing everything :lol:
Ids map here
loot
Re: Loots Mk7 130ps
Postby loot » Sun Jun 16, 2019 1:49 pm
Guys can someone with a mk7 please check relays r23 and r25 as mine are standard 4 pin but the connections are 5 pin and I think that it needs to be 5 on relay on r23 deffo as in the non actuated state it will supply power to low speed.
Thanks.
Ids map here
loot
Re: Loots Mk7 130ps
Postby loot » Sun Jun 16, 2019 1:58 pm
Panic over I've sorted it now.
I bridged pin 5 and output to simulate closed state and now they park and wipe slowly 8)
So are both relays 5 pin then? Thanks.
Ids map here
loot
Re: Loots Mk7 130ps
Postby bambi mk 1 » Sun Jun 16, 2019 2:12 pm
loot wrote:Panic over I've sorted it now.
Good stuff Loot 8)
bambi mk 1
