3244
Re: 3244
Postby Airthies » Mon May 04, 2020 7:26 am
The evidence,
Pics cos it did happen :wink: :D
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby dumper » Mon May 04, 2020 8:52 am
Looking good I’ve always liked weller white 8 spokes had them on my mk2 escort and my mk1 transit when I the fitted the same set them to my mk3 the front surspention used to bottom out on large bumps even with 190 front coil springs on it just to much offset looked good though .
Re: 3244
Postby loot » Mon May 04, 2020 10:17 am
That's a beast that van 8)
07 350 170ps
Ids map here
loot
Re: 3244
Postby Cider Andy » Fri May 08, 2020 11:41 am
Looking good Iain. In particular the colour coded 3.2 front bumper.
Did you manage to find a wheel/tyre size combination in IDS to get the speedo reading close?
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
Re: 3244
Postby Airthies » Fri May 08, 2020 2:55 pm
Cider Andy wrote:Looking good Iain. In particular the colour coded 3.2 front bumper.
No, I've never been able to raise it higher than the 215/75 in the list or even under the manually set diameter option oh well...
I prefer the bumper fully painted rather than with the sections under the lights still bare plastic.
But having said that, I'm itching to start fabing a new alloy one for myself. Honestly how much of a mess can I really make of something like that
Sent from my A55ho11 using Crapatalk
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby andz327 » Sat May 23, 2020 12:36 pm
Like thi pic says what the fook is that on yer hub???? Hub centric adapter on the hub and not welded to wheels ??Image
ANDZ
andz327
Re: 3244
Postby Airthies » Sat May 23, 2020 11:53 pm
andz327 wrote:Like thi pic says what the fook is that on yer hub???? Hub centric adapter on the hub and not welded to wheels ??Image
ANDZ
Precisely
Saved welding in adaptors into basically brand new wheels at the time,
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby andz327 » Sun May 24, 2020 12:41 am
Nice work brother, should make as a kit and sell on the bay
The arch extensions do they fit on lip of arch same idea as door seals ??
Sent from my Samy10+ using Tapatalk
andz327
Re: 3244
Postby Airthies » Sun May 24, 2020 7:56 am
They stick and screw to inner lip, but I've not taken backing off the sticky stuff yet, as wasn't sure about them completely at the time.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby andz327 » Sun May 24, 2020 3:48 pm
Airthies wrote:They stick and screw to inner lip, but I've not taken backing off the sticky stuff yet, as wasn't sure about them completely at the time.
Did you make or buy them??
Has yer ali sheets been dropped at Neds??
ANDZ
andz327
Re: 3244
Postby Airthies » Sun May 24, 2020 8:46 pm
ANDZ
Got the spigots from a guy on FB but got him to make them out of 8mm and larger DIA than normal to fit my specific wheels, then drill and screwed to front hub with M6 Allen screws but ended up making my own top hat style for the rear so there's a lip behind the wheel and then a spacer shim for behind the wheel so the bolts clamp the rim face directly to it since the outer shoulder on the rim is a larger diameter than the halfshaft. I should make two more for the front but the rim shoulder sits ok on the hub. So it's not going anywhere even with the punishment it gets from me.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: 3244
Postby ake » Sat Aug 08, 2020 6:53 pm
Proper van :D
