Okay so, I came into this Transit a few years ago and I believe I did post about it when I first got it, but then university and other project cars kicked and 5 years later I've got back round to it
A bit history its a LWB 88 'F' reg ex-postal van, its a local van having being registered in Leeds. It been parked since about 2004-ish in the mud and a hedge seems to have grown around it so first things first was to dig it out.
So far the resto has consisted of replacing the starter motor, battery and done a basic service which got the engine running, apart from a blowing exhaust it sounds great although the timing seems to be out just a little bit.
Then came moving it out of the mud, I broke three 1/2 breaker bars tying to remove the wheel nuts so I forked out for a 3/4 meter long bar a bit of scaffolding for leverage and they popped straight off. The brakes were also seized so I whacked the drums to loosen the brake shoes a wee bit which enabled me to move the van out of the mud although after using the brakes once when parking the van in the drive all four corners seem to be stuck on.
Now that its on solid ground I'm hoping to start with the bodywork first as that's where it seems to require the most work. Structurally its sound apart from the front chassis section where the front of the leaf springs attach. That's rusted pretty bad.
The aim is to fully restore it and maybe tweak with the engine a bit as the pinto isn't ideal, I have some EFI bits laying around so a pinto turbo might be on the cards but right now I'm focusing on getting it past the MOT stage
