RustWidow wrote:Good work, coming to mania to show it off?
dirtydog wrote:Finally got it mostly stripped out, just a few strips of wood on the floor to pull up
Next job is clean and make it water tight in the back, there's a few holes on the roof from work lights etc that need bunging up and a few on the floor where stuff was bolted through.
The rear most roof join/seam leaks a bit as well so I'll have to cut of the seam sealer and re do it
I can't think of anything I could use the aluminium sheets for in the build so I'll probably just weigh they them in
Also ordered a couple of Varta 110 batteries from Euro car parts for under £60 for the pair as I've found the front battery is as dead as a dodo
Thenugget wrote:
Hi, so happy I’ve come across this chat, I’ve just bought a ex network rail van to convert, however having some serious trouble getting the last panel of the floor next to back doors, the rest of the van floor was 2 metal sheets which we managed to get up and scrap but the last piece is bolted to the van floor underneath, all the heads are rounded off. Been trying to remove for a week, it’s loosened but still not off. Any ideas?
Many thanks
Thenugget wrote:the van floor was 2 metal sheets which we managed to get up and scrap
