Ex Sparkies 06 Connect Day van conversion
Postby blue estate » Wed Apr 15, 2020 2:31 pm
Back at the end of Feb I got my self an Ex Sparkies 2006 90hp TDCi LWB 230lx High roof Connect with 150k on clock .
Being an LX it does have
Heated front screen (craked needs replacing :( )
Heated and electric mirrors
Electric windows
Remote central locking
Remote radio controls
Front fog lights
ABS (rear drum brakes )
Need less to say she was very dirty inside :lol: and has some battle scars on front drivers wing
Also needs n/s sill replacing
blue estate
Re: Ex Sparkies 06 Connect Day van conversion
Postby blue estate » Wed Apr 15, 2020 2:41 pm
I’ve done quite a few jobs so far in the last 2 weeks due to being furloughed from work
1st changed Air and fuel filter and air box to turbo hose
2nd put a set of focus alloys on
3rd changed the steering wheel for a leather mk6 Fiesta one
4th fitted a parrot hand free kit
5th stripped out all the ply lining and swept under it
6th
Lifted cab floor mat and dumped the crap fibre matting and laid some black foam type stuff instead
blue estate
Postby Airthies » Wed Apr 15, 2020 2:45 pm
Looking good blue.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby blue estate » Wed Apr 15, 2020 2:47 pm
Other mechanicals I’ve done so far
Dropped the subframe and replaced ARB bushes
Taken both knuckles off so I can change the lower ball joints and bearings
Also got new set of discs , pads , track rod ends and ARB link rods to go on
Also gear box mount
blue estate
Postby blue estate » Wed Apr 15, 2020 2:48 pm
Airthies wrote:Looking good blue.
Thanks and I'm still being paid while I'm at home :mrgreen:
blue estate
Postby blue estate » Wed Apr 15, 2020 2:51 pm
Monday and yesterday I gave the seats a little clean and now they look blue grey not white black :shock:
Today I've been PVA'ing my loose ply boards so I can paint them
blue estate
Postby blue estate » Wed Apr 15, 2020 3:25 pm
New Floor mats just arrived
blue estate
Postby blue estate » Sat Apr 18, 2020 5:27 pm
Changed the wheel bearings and lower ball joints today and it didn’t all go to plan
O/S went ok and knuckle is refitted on van
N/S different story , got old ball joint and bearing out ok then put new bearing in ok but when I put hub in it pushed rear part of bearing out snapping ABS ring
and when I tried getting bearing back out I snapped a caliper carrier eye so new knuckle on order
Also bolted in the gearbox lower mount
And had this turn up
Sent while in Furlough
blue estate
Postby blue estate » Wed Apr 22, 2020 5:54 pm
Been busy the last few days and I have got a lot done
Monday
Cleaned and washed the inside of load area , also filled all the old ply screw holes on floor with Pu sealant
Also repaired a wiring loom as I screwed through it
And did some sound proofing
Tuesday
Went to B&Q to pick up my insulation and they balls up on the king span
My new n/s knuckle turned up , so managed to fit it along with track rod end Etc
Today
Done more sound proofing , insulation and run some wires also put ply back in for now
blue estate
Postby bortaf » Sun Apr 26, 2020 2:05 pm
Looking good there chap :D
i was going to get a connect as a camper/dayvan/scrap runner before the ambulance came up, due to the amby size i got a fusion as a daily scrap motor instead, still like connects, they are just so much more of a allrounder 8)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby blue estate » Sun Apr 26, 2020 5:30 pm
bortaf wrote:Looking good there chap :D
Thanks ,I would love a larger van but no room on drive for a LWB Transit and aMk2.5 Focus estate :( also can't leave Van where I park my car as we have a Tea leaf problem :evil: :evil:
blue estate
Postby blue estate » Sun Apr 26, 2020 6:54 pm
Rebuilt front brakes today , then put wheels back and took it for a drive
Every thing was A ok
Then came home put the front up on ramps and dropped the oil ,
blue estate
Postby bortaf » Sun Apr 26, 2020 9:22 pm
Same here mate in London, had my fiesta broken into 3 times in dec, 15 yards from my frikken bedroom :roll:
I have 3 web cams for the amby when it comes home, 2 inside one outside 8)
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby blue estate » Sun Apr 26, 2020 9:37 pm
My drive way is ok as I'm on a main road , but I park my car 100yards away in a park entrance and it's got very dark tinted rear windows and tail gate glass
Sent while in furlough
blue estate
Postby blue estate » Mon Apr 27, 2020 4:49 pm
Done a few thing on Van today
Oil change and it still needs another one about months time
Took the roof rack off
Then sanded down and painted any rust patches on roof , and put fixing bolts back in holes with plenty of Pu sealant
blue estate
