Ex Sparkies 06 Connect Day van conversion
Re: Ex Sparkies 06 Connect Day van conversion
Postby RustWidow » Mon Apr 27, 2020 9:30 pm
Coming together there blue, well done
RustWidow
Postby blue estate » Fri May 01, 2020 4:57 pm
More goodies today to fit
Led strip lights and a Sterling B to B charger
Sent while in Furlough
72plt MG 5 ev estate Battery car
blue estate
Postby blue estate » Sat May 02, 2020 6:59 pm
Cut a 5” hole in the floor for the night heater today
Then took rear drums off to check them and shoes
Found out N/S bearing is starting to go also gonna change shoes cylinders and brake springs
blue estate
Postby dirtydog » Sun May 03, 2020 12:00 am
blue estate wrote:More goodies today to fit
The B to B chargers aren't cheap are they? :shock: I'm going with a vsr split charge as I already have the vsr
dirtydog
Postby blue estate » Sun May 03, 2020 9:34 am
that one was £99 + £10 P&P as it's a refurb one from Sterling power them selves so has updated software as well
Also brought a roof vent/ skylight yesterday it's 280mm X 280mmhttps://www.ebay.co.uk/itm/MPK-280-ROOF ... 2749.l2649
blue estate
Postby dirtydog » Sun May 03, 2020 12:57 pm
That's a brilliant price for one is those 30a chargers, nearly double that for new. Might have to have a look at getting one of those. Next on my list is solar I think
dirtydog
Postby blue estate » Sun May 03, 2020 12:59 pm
dirtydog wrote:That's a brilliant price for one is those 30a chargers, nearly double that for new.
That's why I got it , just got to get all the wiring and fuses for it now
blue estate
Postby blue estate » Wed May 06, 2020 3:29 pm
Cut ,laid and stuck down floor battens 50mm x 25mm also cut 25mm off my 2 ply side boards so they'll fit back in
I will post pics tomorrow when I start fitting the cellotex board and taping up the joints
blue estate
Postby blue estate » Fri May 08, 2020 3:48 pm
Yesterday , laid floor insulation then taped joints up and then trimmed the floor ply and screwed it down
Today started fitting night heater
Will post pics up tomorrow as I hope to have it working , also waiting on a smaller fuel tank
blue estate
Postby dirtydog » Tue May 12, 2020 3:51 pm
Don't forget your vapour barrier
What floor covering are you putting down?
dirtydog
Postby blue estate » Tue May 12, 2020 4:13 pm
Getting some tough vinyl from eBay
blue estate
Postby dirtydog » Tue May 12, 2020 4:52 pm
I've got an off cut of Altro flooring left over from mine that might be big enough for your connect, yours if you want it
dirtydog
Postby blue estate » Sun May 17, 2020 8:03 pm
Been busy last few weeks ,
Replaced hand brake cable , rear shoes and rear bearings
Fitted night heater and all working fine just got to secure fuel line once cupboard is built
Also cut wood to size for bed ready to fit later in week
blue estate
Postby blue estate » Thu May 21, 2020 3:25 pm
Had a busy week , cut all wood ready for the bed and cupboard/night heater hidie hole
Sanded the bed slats , put some silver bubble wrap up , sound deadened the roof , fitted roof vent and laid the vinyl floor
Sent while in furlough
blue estate
Postby tangod » Sun May 24, 2020 5:40 pm
Good job...
You having some sort of bed in it?
Ex rac transit 2007 2.4 Rwd mk7 .
Anything 4x4..
tangod
