Mk5 turbo diesel auto
Postby Adam mk1 » Wed Sep 02, 2020 3:33 pm
There's not much to do but i suppose it should be in progress column, i bought this couple of weeks ago off ebay, was on limp mode running on after switching off, that has now been sorted thanks to minor matt supplying a plunger and help and advice fitting, so thanks bery much matt, the next thing to sort is the gearbox its dreadful 1st and 2nd hold much too long 3rd only comes in at 42 coming off the gas with a thud, and 4th has retired completely, so around town is bearable over 50mph its reving, the van does come with a spare box, and ill try and fit that in the next couple of weeks & see if that's any better!!!!
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Re: Mk5 turbo diesel auto
Postby Adam mk1 » Wed Sep 02, 2020 3:35 pm
Adam mk1
Postby Adam mk1 » Wed Sep 02, 2020 3:37 pm
Adam mk1
Postby Adam mk1 » Wed Sep 02, 2020 3:40 pm
Adam mk1
Postby Adam mk1 » Thu Sep 03, 2020 9:32 pm
Adam mk1
Postby Adam mk1 » Thu Sep 03, 2020 9:35 pm
Do all the automatics have this, does it also put u in limp mode :lol: im guessing pulls away with less power?
Adam mk1
Postby MinorMatt » Sun Sep 06, 2020 1:52 pm
No they don't
Thats traction control...
Postby Adam mk1 » Sun Sep 06, 2020 6:28 pm
Ok thanks matt, mine doesn't have LSD from vin decoder so how does it work please, ive not looked under it yet
Adam mk1
Postby Adam mk1 » Sun Sep 06, 2020 6:31 pm
Van is revving at 55mph, again from vin decoder had 456 or 463 diff but gearbox is playing up so not sure if its going in top missing 3rd gear or its in 3rd
Adam mk1
Postby MinorMatt » Mon Sep 07, 2020 9:26 am
Adam mk1 wrote:Ok thanks matt, mine doesn't have LSD from vin decoder so how does it work please, ive not looked under it yet
It detects if a wheel is spinning and applies the brakes to transfer drive to the other. It uses the ABS system
Postby Adam mk1 » Tue Sep 15, 2020 9:54 pm
Adam mk1
Postby Neil » Wed Sep 16, 2020 7:27 am
box goosed
Neil v6
Neil
Postby Chug » Wed Sep 16, 2020 9:12 am
Have you checked/changed the gearbox oil?
Chug
Postby Adam mk1 » Wed Sep 16, 2020 11:00 am
I did put a litre of fluid in gearbox and it cured itself for 10 miles then it uncurred itself, so ill try oil & filter, also I've been given a granda mk3 with a A4LD geabox in it, but its a 92 car so think none electronic gearbox but that might do for my mk1 transit
Adam mk1
Postby Adam mk1 » Wed Sep 16, 2020 5:37 pm
Adam mk1
