The cube rebuild
The cube rebuild
Postby hitman » Tue Sep 25, 2007 11:21 pm
finally got it in garage an started to strip it
hitman
Postby dangeeeeerousss » Wed Sep 26, 2007 2:14 am
come on hitman whats your plans are we having that 4.6 in then or what :lol: :wink:
dangeeeeerousss
Re: The cube rebuild
Postby hitman » Sat Oct 13, 2007 12:04 am
trial fitted the 3.5 v8 an made the engine mounts, cut out the bulk head to get better weight transfer
then back out an all front is now off axle the lot :mrgreen:
hitman
Postby madmark » Sat Oct 13, 2007 5:38 am
wow this is going to be so cool when its done ! 8) 8)
Postby baby stepside » Sat Oct 13, 2007 6:12 pm
its looking good :D
tis eye leclair
mk5 flareside with taillift and im keeping it
baby stepside
Postby DOL » Sat Oct 13, 2007 9:01 pm
nice :D mrs dol loves ur van :D
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Postby hitman » Sat Oct 13, 2007 11:13 pm
waitin on a reply to a modified v8,4.6 fell through(no contact from seller)if not will rebuild the v8 iv got to nice spec :twisted:
hitman
Postby dangeeeeerousss » Sun Oct 14, 2007 1:16 pm
hitman
i have a pair of carbs for that engine if you want them you can have them mate
dangeeeeerousss
Postby hitman » Fri Oct 19, 2007 9:23 pm
thanx dangerous but i bought engine less carbs as i dont like em,want either a weber or a holley :twisted: ,seen some cherry bombs on the bay 2 1/2 inch bore :lol: ,oh an a nitrous kit 8) well why notImage
hitman
Postby dangeeeeerousss » Sat Oct 20, 2007 2:34 pm
hi hitman
i like cherry bombs i was gonna get some cherry bomb centre boxes but i havent seen any for years they are all back boxes.
the back boxes im gonna have made i want twin 12"x8" ovals each side :lol: then lpg and later nitrous.
ive put a fast road cam into the v8
if i get anybit or theres any you need give us a shout and ill see what i can do for you theres a few guys here that deal with v8 stuff here cheap and if i can beg it you can have it!
looking forward to seeing your van again and seeing what youve done
dangeeeeerousss
Postby hitman » Sat Oct 20, 2007 4:53 pm
cheers dangerous :D ,just waitin for a reply on the that modified v8,if it dont turn up im gona build one myself so il let u no what parts i need an see if u can help :wink:
hitman
Postby sus » Sun Oct 21, 2007 8:39 am
if you stick with the 3.5 put 3.9 cams in they suit a van as they give more torque, did the same when i built an old landy for off road fun :D
connect 110T200 with aircon
sus
Postby snap-on » Mon Oct 22, 2007 11:23 pm
What axle are you going to run?
Dave
snap-on
Postby madmark » Tue Oct 23, 2007 12:48 pm
yes i agree a nice 3.5 or 3.9 ,i had a twin choke webber carb on mine and this gave me around 24 mpg on a run ,i couldnt even get that from a essex v6 :shock: :shock:
the other carb would be a 390 holley 8) the su carbs are a very slow carb as they dont have throtle pumps ,as with the twin choke webber it transformed the engine !wow i would like another v8 but i just cant chop the mk1 about! :(
also the gm350 engine is all the rage now days and parts are alot cheaper than the rover! 8)
Postby hitman » Wed Oct 24, 2007 11:17 pm
spring hangers an front crossmember :( ImageImageImagebut some good bits :wink: :mrgreen: ImageImage
hitman
