Chasing the Tin worm
Postby Welder64 » Sun Jul 03, 2022 6:33 pm
hi everyone have just started to do work on my MK7 and will be asking questions as i go am sure. Here is the first of the pics , my intention is to eradicate the rust front to back.
Welder64
Re: Chasing the Tin worm
Postby Welder64 » Sat Jul 23, 2022 2:58 pm
More rust under the N/S front wing , think i need a new inner panel as well .. any one done this section before could do with a few pointers.
Welder64
Postby Welder64 » Fri Jul 29, 2022 9:47 am
finally finished cutting the crap out of the N/S step and inner wheel arch and inner and outer sill, started to offer up panels that i have cut to size to ensure a neat finish, just waiting on the inner wheel arch splash panel to turn up so i can dummy fit with the other panels before welding. I guarantee if i just went ahead and welded before i joggled all the panels into some thing will look mis aligned. Lots of surface rust to be treated before i weld in new panels and box in that section
Welder64
Postby Brettbear63 » Sat Jul 30, 2022 8:19 am
it looks quite rusty , a real labour of love ?
Brettbear63
Postby Welder64 » Sat Jul 30, 2022 9:55 am
It is rusty in all the usual places brett , but its got a good engine and i will never put an old transit to sleep.
Welder64
Postby Brettbear63 » Sat Jul 30, 2022 6:29 pm
Welder64 wrote:It is rusty in all the usual places brett , but its got a good engine and i will never put an old transit to sleep.
Brettbear63
Postby Welder64 » Sun Aug 07, 2022 3:55 pm
Today was another challenging episode, had to cut a portion of the N/S panel by the door to slide in the a new splash guard panel, only way i could get in there.
Welder64
Postby Welder64 » Thu Aug 11, 2022 5:41 pm
Final fit before welding starts , seems to have taken forever but so close.
Welder64
Postby Welder64 » Sun Aug 21, 2022 11:43 am
cant believe the bloody weather , forecast was for slightly overcast with intermittent breaks of sunshine , woke up this morning got everything ready to start welding and now rain. Its a right pain in the arse when you aint got a garage or driveway and you have to work on the roadside.
Welder64
Postby Welder64 » Mon Aug 22, 2022 10:22 am
bit more welding done
Welder64
Postby ned » Mon Aug 22, 2022 10:26 am
How bad was the inner arch before you changed it? Mine is rusting on both lower front arches so just want to get everything I need before cutting bits off.
Starting to look like it should now, keep up the good work
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Welder64 » Tue Aug 23, 2022 11:42 am
inner splash arch was rotted from bottom to top , as was the inner lower sill and the N/S step. Had to cut the outer lower wheel arch section out to get in there to chop out all the rotted metal and slide a new inner arch into position , bought panels from " Central panels auto parts". total cost for all panels was about £200. The way i looked at it was the time it would take to try and fabricate bits of steel into a decent shape to fit into the area i needed it was cost effective to use as much of the pre fab panels and put in as much new steel as possible for a cleaner look.
Welder64
Postby Welder64 » Thu Aug 25, 2022 7:31 am
Still slowly cutting ,shaping and i reckon another couple of sessions will be fully welded in and under sealed. Then its over to the O/Side which is not as bad but still will need to replace at least 3 panels. inner and outer footwell sills and the step.
Welder64
Postby Welder64 » Thu Sep 01, 2022 10:58 am
Footwell all in and welded and primer applied .Before and after.
Welder64
Postby Welder64 » Mon Sep 05, 2022 7:46 am
a little more welding yesterday before the heavy rains and lightning descended, have now buttoned up the outer wing and it is starting to look so much better , just one more session of welding on the N/S and i can fullu seam and underseal the whole area and move on to the drivers side. Be nice to have some guesses on how much you think i have saved by not having my local garage do this work as it may have taken them less time but up to now with all the panels i have purchased to do the job its cost me £200.
Welder64
