Wing mirror shear bolts
Postby Welder64 » Mon Jul 04, 2022 10:10 am
So today was get to those pesky shear bolts , read all the posts on the subject on here and decided to go for open mirror surgery. As drilling a pilot hole was not working i realised if i made thin cuts to open up the area then i could plastic weld the pieces that are cut out back into place , fill and respray the mirrors, at £40 plus for new mirrors i thought it made sense. So with grinder and a 1mm cutting disc i cut 2 neat areas out and can easily drift the bolts out , 10 minutes later all done , result.
Welder64
Re: Wing mirror shear bolts
Postby Brettbear63 » Sat Jul 30, 2022 8:22 am
if its just a knackered mirror could you not just replace all the knacked bits with parts from a cheap replacement mirror ,? , my cheapo new L/H mirror didnt fit at all , so i just transferred the glass and backing bits to my old one .
Brettbear63
