Kiwi Mk2 5 litre transplant
Postby kiwi_mk2 » Sun Dec 02, 2007 1:25 am
Finally the transplant has begun, engine bay stripped of everything and awaiting the new engine....
After much measuring the firewall needed some cutting......
Now offer the engine up and.....
Now for some mounts....
I have decided to use 2 of the original mounting holes and fit a new crush tube and captive nut for the rear holes of the new mounts. These two new mounts will be joined together underneath to make a nice strong subframe
I want to take my van to Gatwick and park it in the Transit lounge!
kiwi_mk2
Re: Kiwi Mk2 5 litre transplant
Postby Luke » Sun Dec 02, 2007 11:14 am
top project 8) 8) 8)
i'll look forward to reading this one :D
Postby rover » Sun Dec 02, 2007 11:31 am
Nice work mate 8)
I'm so jealous of the engines you have over there :wink:
Rover.
rover
Postby vannut » Sun Dec 02, 2007 1:40 pm
I'm just jealous of the lack of rust! :lol:
Where's me anorak!!!
vannut
Postby kiwi_mk2 » Wed Dec 05, 2007 9:37 am
Well i'm jealous of all the cheap and readily avaliable 5 speed boxes you guy's have over there...... Need a T5 soon.....
kiwi_mk2
Postby Sundowner » Wed Dec 05, 2007 10:19 am
kiwi_mk2 wrote:Well i'm jealous of all the cheap and readily avaliable 5 speed boxes you guy's have over there...... Need a T5 soon.....
I dont think you'd want to run a UK spec T5 better off going for one from a falcon or commodore
Very nice van btw 8)
Sundowner
Postby kiwi_mk2 » Sun Dec 16, 2007 10:17 am
After a few more hours work the right hand mount is finished ! Just a little tidying and these can be painted... finally :D :D
Since i have finished using the engine for mounts and firewall mods i can now spend some time ( and $$$ ) and strip it down and see what sort of condition it is in....
Sorry for the lack of photo's too... :oops:
kiwi_mk2
Postby WRECKERSTEVE » Wed Dec 19, 2007 8:40 am
did you have to fit it that far back or was that optional and iy looks a very narrow engine
you break it i take it
WRECKERSTEVE
Postby Sundowner » Wed Dec 19, 2007 9:28 am
how do you know if the engine is in the correct position?
once the engine and box are mounted will it have the correct box to pinion angle?
Is the engine going to be EFI or carb?
Sundowner
Postby kiwi_mk2 » Fri Dec 21, 2007 7:54 am
WRECKERSTEVE wrote:did you have to fit it that far back or was that optional and iy looks a very narrow engine
Idecided to fit it that far back to keep the weight back as far as i could , the engine is a Windsor so it it a little narrower than a Cleveland, plus it's only a Small Block compared with Sundowners Big Block!
kiwi_mk2
Postby kiwi_mk2 » Fri Dec 21, 2007 8:01 am
Sundowner wrote:how do you know if the engine is in the correct position?
I took a few measurements off the 2 litre to give me some idea of where to sit the new one plus i'll be fitting a 9" axle once the engine and box are mounted so if there is any adjustment to do i can do it then.
The engine will be running a carburettor and electronic distributor,
Cheers for the heads up about T5's too.... looking for a Falcon one now :)
kiwi_mk2
Postby Luke » Fri Dec 21, 2007 4:09 pm
yeah mate get it sitting as far back as you can - ive got problems getting the power down in mine :o and its only a 2.9V6 :shock:
quality engineering work btw 8)
Postby vannut » Fri Dec 21, 2007 5:54 pm
kiwi_mk2 wrote:After a few more hours work the right hand mount is finished ! Just a little tidying and these can be painted... finally :D :D
That's a lovely bit of quality welding mister. :D
:mrgreen:
vannut
Postby Sundowner » Fri Dec 21, 2007 11:29 pm
With some luck it will work out
With the body level i float the engine and box (box on jack engine on lifter) in its desired position the set the tail shaft angle and make a gearbox x member (it will change slightly one the engine mounts are done)
Once the box is bolted in i fine tune the engine position by sitting a small level on the manifold where the carb mounts and then adjust to make this area level, its important to get it right as the wrong engine angle can effect the carbs behavior and sometimes effect the oiling system and create air pockets in the water jackets
Once its all sitting right its then time to do the engine mounts
Sundowner
Postby vannut » Sat Dec 22, 2007 2:59 am
'kin 'ell! Technical innit! :lol:
vannut
