Red one
Red one
Postby loot » Sun Jan 14, 2024 1:36 am
2006 ford transit mk7
2.4L tdci 140ps
Swb,medium height,single side door,barn doors.
6 speed Rear wheel drive, 4.27 axle ratio.
High spec glx model with heated screen/mirrors/electric windows and air conditioning.
98k miles with service history.
Since 2020
Rear brakes,new turbo,break pipes replaced. Serviced etc.
Purchase price £1350+ 100 for insurance and transport to collect it.
Progress report so far.
Removed the tatty plywood interior and roof cubby
And checked around it for rust appraisal.
Ids map here
loot
Re: Loots mk7 forskin
Postby Airthies » Sun Jan 14, 2024 1:40 am
Is it done yet?
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Jan 14, 2024 1:44 am
Some pics of the rust etc
Ids map here
loot
Postby loot » Sun Jan 14, 2024 1:46 am
Today's job remove ply,thankfully it's a pile of dust from under the put and not rust :lol:
Ids map here
loot
Postby loot » Sun Jan 14, 2024 1:47 am
Some shiny batteries but 2017 :(
Ids map here
loot
Postby loot » Sun Jan 14, 2024 1:54 am
Pics from me looking around
Ids map here
loot
Postby MinorMatt » Mon Jan 15, 2024 4:29 pm
The guy said he thought it was too rusty too fix
Whats your initial thoughts?
Postby loot » Tue Jan 16, 2024 3:45 pm
MinorMatt wrote:The guy said he thought it was too rusty too fix
It's not that bad, 2 full sills and a long plate on the inner sills to match. Front n/s inner arch panel or plate. Today I knocked the inner rear arch and the sealant and metal came off so it'll be a length of angle iron on both of them to secure that. The bit you've seen in the photo in front of the n/s/r wheel it's a jacking point I think. The back has had a lot of welding done before so it's good.
Today I removed the rear bumper and spare wheel. It mostly wants a good rub down then a go of jenolite if yous recommend it then hammerite then shutz. I may replace the brake pipes.
It's had a brand new n/s/f caliper and o/s/r caliper.
The whole underneath is crusty , chassis,exhaust,sub frames,axle etc like it has be laid up in a field. I would like to remove it all and clean it properly but I'm not sure I will have time.
Tidied the layout today too give me more room. For now it's all good progress.
Ids map here
loot
Postby loot » Sun Jan 21, 2024 5:47 pm
Decided that even though I could spend hours plating the inner rear arches, I would spend 100gbp on 2 new ones. Spent an hour so far removing the old ones and drilling the spots out etc. I'll spot weld the new ones in. And actually spend a lot less time and consumables I think plus it's all new. :P
Ids map here
loot
Postby Airthies » Sun Jan 21, 2024 7:48 pm
Are you removing your towbar?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Jan 23, 2024 5:30 pm
Airthies wrote:Are you removing your towbar?
Sorry Iain yes I have,I needed to stop I could remove the Reinforcement bit, but more because the step bumper I bought won't let me use the tow bar as is . I want a detachable 1 anyway.
Ids map here
loot
Postby loot » Tue Jan 23, 2024 5:36 pm
Chasing the rust along the n/s to the front, removed the wing and door.
Ids map here
loot
Postby ned » Tue Jan 23, 2024 6:32 pm
Looks like a religious process, very holy :lol: :lol: :lol: what’s the big plan with this, roof chop, 3.2L engine, flames on the sides, mattress in the back
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Airthies » Tue Jan 23, 2024 6:35 pm
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed Jan 24, 2024 1:19 pm
Airthies wrote:https://www.facebook.com/marketplace/item/324248557092153/
Might be a good buy for someone. Bit steep for me though :wink:
I think with my 2.4 remapped I'll be spinning in every gear anyway :lol:
Ids map here
loot
