FORD HYMER ENGINE GEARBOX AND PROP UPGRADE (FINISHED)
Postby JIM T » Wed Jan 09, 2008 7:12 pm
09/01/2008 TOTAL HOURS WORKED 10
Stared with getting the Hymer up on ramps and then taking the face off, it came off well just 16off self tapping srews for the trim and 6off 13mm nuts and bolts with 2off 17 mm nuts for the rad , (big rad )the electrics had been cut and reconnected with bullet conectors some months befor it was not the cow of a job I thought it was going to be.
Started to dissconnect everthing from the engine ,with the frount off it was a great job and I enjoyed every minute .I then started to take off the exhaurst all 15 foot of it but some German Had welded every joint so I had no choice but to take it off in one length it came out like pulling a elephants tusk stright through the engine bay(pig of a job) .
Next came the engine lift it did not go right from the start I could not get the crain near enough to the engine when I lifted the engine up it fouled the under side of the dash anyway after a few attemps at getting the crain closer it poped out ,it still court on the lip at the top of the opening but no damage (may be I should have taken it out through the bottom like salourman did BUT HE HAD A PIT).
Yes it is a Transit MK 2 under there some were.Click here for pic!
[http://s233.photobucket.com/albums/ee82/JIMRT/#!cpZZ7QQtppZZ16]
JIM T
Re: FORD HYMER ENGINE GEARBOX AND PROP UPGRADE
Postby JIM T » Wed Jan 09, 2008 9:12 pm
This is the pump of the old engine, Luke it was a bosch
JIM T
Postby rover » Wed Jan 09, 2008 9:37 pm
Good work up to now Jim :D
I take it the new exhaust is in sections then? :lol:
Rover.
rover
Postby JIM T » Wed Jan 09, 2008 9:46 pm
09/01/2008) 4 Hours work
Now it was time for the new MT75 gear box I know I have to cut a hole for the gear lever but at the moment it is fouling the crossbeam and I think I need a gear box mounting off a MK5 and I still think the box will foul the crossbeam. The box is a lot lighter than the 4 speed but it was still heavy anyway it's time for my tea so that's it for the day.(5.30 pm) :) :) .
JIM T
Postby JIM T » Wed Jan 09, 2008 9:48 pm
rover wrote:Good work up to now Jim :D
Rover.
It better be or the hachsaw comming out :) :)
JIM T
Postby Luke » Wed Jan 09, 2008 9:49 pm
good work jim :D if you want to weld the mk5 floor in for the correct surround fot the new box stick this is all you need :arrow:
its the one ive fitted to mine :lol:
and that will sit on the floor lining up perfectly :D
Postby JIM T » Wed Jan 09, 2008 9:56 pm
Did your MK 2 have a dirty great big crossbeam Luke ,and did you have to cut it to get the box back to right position. I think its a trip to the scrappys again anyway :)
JIM T
Postby Luke » Wed Jan 09, 2008 9:59 pm
i made a g/box crossmember out of a mk5 one with home made mounting point brackets - i had extra problems with the ifs beam as the V6 engine is deeper than the Di :D
Postby JIM T » Wed Jan 09, 2008 10:06 pm
LOOK LIKE THE BURNNIG TACKLE IS COMMING OUT :twisted: :twisted:
JIM T
Postby pete_the_4x4 » Wed Jan 09, 2008 11:51 pm
like your van :lol:
if you think my van is dirty you should see my pants
pete_the_4x4
Postby JIM T » Thu Jan 10, 2008 12:02 am
Ta mate :)
JIM T
Postby JIM T » Thu Jan 10, 2008 7:28 pm
10 Jan 2008 2hours work
not much don today I knackered my self up so I only worked in the garage, I took the EGR system off to give me more room when I put the knew engine in. The two bolts that hold the stainless tube on the manifold were over tight so I had to warm them with the gas welder they came off but only after I had hammerd a 9mm ring spanner onto them the rust had taken them down from 10mm thats about it . :)
JIM T
Postby JIM T » Fri Jan 11, 2008 6:01 pm
11 JAN 2008 2 HOURS
Started the crossbeam modifications today and they were not too bad .I had to cut a rectangle shape peace out of the middle of the crossbeam you can see in the photo it has weakened it so I will weld a peace of 13 mm 1/2 inch round bar bent round the gear box to put back the strength . I need to make a rubber engine mount out of some 5/8 thick rubber belting to stop any vibration being transmitted through the crossbeam from the gear box and prop the MK 5 mount would have been to tall [size=150](QUESTION /THE PUMP ON THE OLD EMGINE HAD THREE PIPES TOO AND FROM THE THE TANK ,I THINK ONE WAS A RETURN IT IS SMALLER THAN THE OTHERS AND ONE MUST BE THE FEED BUT THE ONTHER ONE I HAVE NO IDEA CAN ANY ONE HELP) [/size] :D :D but Knackered again.
JIM T
Postby Luke » Fri Jan 11, 2008 7:12 pm
cracking on i see jim 8)
how i did mine was to use the mk5 rubber mount and site the cross beam in the correct position - then make hangers to suit :D
Postby JIM T » Sat Jan 12, 2008 10:17 am
The crossbeam on the Hymer is mounted on rubber mounts at the point were it attaches the chasse , not bolted straight to the chasses and a peace of flat rubber placed between the gear box and the crossbeam will give it the same movement as a MK 5 gear box mount . The MK 5 has different engine mounts ,they have a support bracket that touches on the gear box .
On the LDV convoy I have just sold it had the same gear box MT75 but with a Peugeot engine they used a peace of box section bolted from the engine mounts to a point near the clutch cable hole I will make the same support for the Hymer . :)
JIM T
