Wiring - swapping equipment from a custom to a non-custom
Postby juliantlee » Sun Jan 13, 2008 11:06 pm
Does any one know whether the wiring in one vehicle is the same as the next and it just a matter of plugging in other equipment. I have a 115ps turbo van and it not a custom. Can I transfer central locking, electric windows etc. I know already that a display with rev counter does not work even though it plugs straight in and everything else works. What would be missing that a custom model has to run the rev counter. Can anybody help ?
1995 County 76ps x 2 (IFS)
1996 190 Custom Turbo 85ps
2000 190 115ps Turbo intercooler, 4.66 rear axle
2006 350 115ps Di, 3 way tipper with 1.4 t hiab crane
2006 350 135ps TDCI GLX
2011 350 140 TDCI Limited (remapped by Vantunner)
juliantlee
Re: Wiring - swapping equipment from a custom to a non-custom
Postby Guy88 » Sun Jan 13, 2008 11:16 pm
you need to run a wire from the alternator slate grey to the small plug pin 9 at the cluster.
as for the rest you may be lucky. if not swap the whole cab loom
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby juliantlee » Sun Jan 13, 2008 11:21 pm
So you've done this before. There are 2 clip in connectors and if I remember correctly, the larger cream/yellow clips into the side the rev counter is on. Can't be too sure as thevan is in Devon and I am in Gibraltar but I'll have a look next week. So the wiring loom inside the cab is independant to the wiring in the engine bay.. is that what you're saying ?
juliantlee
Postby Guy88 » Sun Jan 13, 2008 11:30 pm
there is a white and a black one. you need to run the wire to the smaller one
The loom plugs in by the battery
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby juliantlee » Sun Jan 13, 2008 11:36 pm
Thank you, I have alot to learn but I'm very keen. I have 3 transits at the moment and sold my orginal S-reg 100 SWB Custom a few weeks ago, but it was devoid of custom bits apart from the heated windscreen, as I took them all out. I appreciate the advise.
juliantlee
