Been away a while.... following the disconnection of my testicles
the carpet is automotive carpet from Ebay £11 a roll about 2M square... i have gone through 4 rolls now!!! and you need spray adhesive to sick it which is great on wood but if you need to stick to roof or any metal body panels, you are best using the high temp stuff as the standard stuff melts on a warm day.... i need to get some high temp for the ceiling.
we took the van to alton towers for a weekend and i managed to lock the keys in the back while loading up for the return home... the rear doors lock automatically sometimes... luckily the side door was still open and i smashed my way through the bulkhead just enough to pass my 4 year old son through the gap and unlock the door for us.
I ditched the bullbar and visor as the van is for my kitchen and bathroom installation business and i want it as proffesional as possible. it has just been sign written and once i fix the bulkhead and finish off a bit more work, i will be fitting a Laptop pc and printer in the back so that i can do Designs and written quotes on the spot, Once the van is back on the drive, the laptop will be linked to the home network via Wifi and i can upload and download info as required.
Also on our alton towers escapade, i went under a low barrier and damaged the spinning air vent on the roof!! it is now a bit off centre and at 70mph causes huge resonance problems in the back... can i take it off? is there a blanking plate or something i can put in its place??
Another thing i have been working on is a heater duct. the hot air stays inside the front cab and doesn't circulate into the back so i'm fitting a 12v extractor fan into the headlining in the front cab ducting it into the back section so it comes on when the heater blower is on full which should draw all the hot air from the front and allow the kids to defrost!!
