bullbar has gone, work has started
only cleaned the rust out of the right hand side so far.....the other side is worse....
lower rear quarter.....
new panel trial fitted....
edgesetter helps get the fit right...
take note int
hole on the inside ove the spring hanger outrigger....
lots of small holes....
and an odd one, rusting from under the paint but no visible hole in the paint inside or outside
front arch, bit of surface rust and a small hole caused by the mudtraps....i mean mud flaps
and the step......sad face
while i was at it i fitted these.....
