Got the shed painted...
Postby pumpkinhead456 » Sat Dec 13, 2008 11:01 pm
Better start from the start I suppose...
Bought the van from Ebay last weekend, picked it up 50 miles away and drove it home with the trade plates on. No MOT or tax, but we can soon sort that... can't we? :?
Saw it today in the light for the first time, first problem was a very dead battery - no worries, got it jumped. Parked up in an actual shed, got the fibreglass out and went over the arches the best I could. Air powered sander moved things along swiftly :D That was the first time I have ever whiffed fibreglass and really enjoyed working with it! On the down side the wings are completely rotten and will need fixed properly soon enough.
Few other rusty bits on the bottom of the door and sills, so out pops the Hammerite and I slapped it on good and thick!! Turned out a wire to the alt' was broken so the battery was never getting to charge, that was a very quick fix and it starts great first time now.
An area of pretty large concern is the equally large hole in the passengers footwell. Aparently the guy that's doing the MOT knows exactly how to weld rust to rust so fingers crossed it's not completely rotten.
Anyhoo, the van is heading for it's MOT on Monday, so I might be kind and let you all know how it gets on :wink:
TTFN
1995 190 LWB Luton 2.5 Manual, Ex BT, Ex good condition, 2.25 seats, 0.96 lutons, 0.4 front wings but a private number plate! Woopwoop. Oh, but no MOT or tax. 1 Carefull owner, 1 not so...
pumpkinhead456
Re: Got the shed painted...
Postby BigNeil » Sat Dec 13, 2008 11:08 pm
no pictures not even the ones off ebay ?
BigNeil
Postby pumpkinhead456 » Sat Dec 13, 2008 11:29 pm
BigNeil wrote:no pictures not even the ones off ebay ?
You people are so "picky" :P
These are the photies from ebay. Looks like an ex BT van, it's not! It's an ex BT luton but the cab used to be blue and looks hand painted!!
pumpkinhead456
Postby BigNeil » Sat Dec 13, 2008 11:43 pm
vehicle colour is blue !
you might want to change the paper work for this !!
looks ok though
thank you
:D
BigNeil
Postby Missile » Sun Dec 14, 2008 1:36 am
That back end is off a later van, we didn't have them till the mk6 cabs, the earlier ones were flat sided boxes no streamlining.
Missile
Postby paultic » Sun Dec 14, 2008 1:37 am
i'm just up the road a bit from u in mayfield
good luck wi the van it makes mines look minted :o
paultic
Postby bigmastif » Sun Dec 14, 2008 3:09 am
Missile wrote:That back end is off a later van, we didn't have them till the mk6 cabs, the earlier ones were flat sided boxes no streamlining.
if your talking about the box bt fitted them on mk4-mk5 chassis
mk6 one is almost the same apart from its white and has a lower luton section :wink:
bigmastif
Postby Guy88 » Sun Dec 14, 2008 10:52 am
yea thats a mk5 box, you can tell its old by the outline of the old style stickers on it
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby PXR5 » Sun Dec 14, 2008 11:41 am
The prancing piper logo was a rebranding in 1995 and there were versions of that logo within BT where he was bent over with his head up his arse, and another where he was blowing the trumpet from his arse. Now those would look good on your van! Sadly now it's only the globe of Openwoe as it's known within the ranks, and there's not much comedy in that logo. Bring back Busby :lol:
PXR5
Location: North Yorkshire, Scotlands second missing county
Postby pumpkinhead456 » Sun Dec 14, 2008 4:12 pm
It looks good from afar but is far from good! I guess we will find out tomorrow if it's a real lemon or not.
Speaking of that lovely BT goddess etched in the dirt, anyone know the best way to get rid of the outline? I thought about letting someone go wildstyle with graffiti but maybe that's a bit extreme :lol:
Also as mentioned above it is a fair lift to get gear in the back, I will have to fabricate a step of some kind. Looks like it's had the pneumatic lift at some stage. I was planning to deck out the rear floor with 3mm ply, any suggestions good or bad?
I am in the fortunate position of having access to great tools and an agricultural workshop where I can get some space and warmth. I am in the unfortunate position of not having a clue what I am doing tho!!!
Thanks for your kind welcome :D
pumpkinhead456
Postby bigmastif » Sun Dec 14, 2008 5:40 pm
pumpkinhead456 wrote: anyone know the best way to get rid of the outline?
wash it then t cut it easiest and most inexpensive way apart from painting it :!:
bigmastif
Postby pumpkinhead456 » Mon Dec 15, 2008 3:30 pm
MOT day today - how exciting (for my bank manager!)
pumpkinhead456
Postby MinorMatt » Mon Dec 15, 2008 6:34 pm
and the result was........??
I guess you are either happily driving around or underneath with a welder :lol:
Postby pumpkinhead456 » Mon Dec 15, 2008 7:31 pm
Sadly the later - sniff sniff.
2 dodgy tyres (must have been close!), wheel bearing, brake line and 3 holes needing welded. Couple o other wee bits and pieces - all in £400 max.
Now had I had any knowledge with a welder I may have attempted things myself, however as I don't I shant!! :)
So could have been better, could have been worse. At the end of the day that's £750 for the van and a years MOT along with the private plate (which I have been offered £300 for!), so can't grumble.
Will let you know how the fixing goes and maybe even post a wee pic or 2 8)
pumpkinhead456
