welshrussel's Mk1 Campervan 'Big Liz'
Postby Dan T » Mon Feb 09, 2009 7:13 pm
Here's a Picture of 'Big Liz' before she undergoes her long awaited transformation 8)
I hope to keep everyone updated (especially Russ) with her progress from when she arrived on saturday untill she leaves all painted and hole free.
It may end up good enough for a space on the 'Featured Transits' page :wink:
We had a tough time starting her this morning, but after a while she was up and running and we moved her into our second workshop (The Project Workshop) to rest untill she's ready for painting.
Dan T
Re: welshrussel's Mk1 Campervan 'Big Liz'
Postby madmark » Mon Feb 09, 2009 7:21 pm
yes keep us all posted and plenty of photo,s if you can :wink:
why does it not start ? should go easy ????
Postby Dan T » Mon Feb 09, 2009 7:30 pm
madmark wrote:why does it not start ? should go easy ????
Should run and start sweet, but it's quite rough at the moment.
It needs a good tune up and we think it may only be running on 3 cylinders, but all will be perfect when were finished :D This is the first job on the agenda anyway.
Dan T
Postby madmark » Mon Feb 09, 2009 7:31 pm
:roll: just such a shame you are so far away from me! :(
Postby bigmastif » Mon Feb 09, 2009 7:46 pm
supperb :D was hopeing to see you get this job dan :wink:
look forward to the transformation and ill be watching it progress
bit tight in there tho :shock: :lol: :lol:
bigmastif
Postby Luke » Mon Feb 09, 2009 8:52 pm
oh yes :!: should be a good thread 8) plenty of pics please Dan :wink: :lol:
Postby welshrussell » Mon Feb 09, 2009 9:38 pm
Aah No :shock: :shock: Sorry Dan :oops:
Funny you should mention 3 cylinders, the AA guy who had to give me a jump start on Saturday mentioned this :roll:
It seemed like she ran rough then was fine being warmed up and hit speeds of 50/55mph on the M8 :wink:
I'm sure there'll be something to help you in one of my boxes of bits :wink:
Glad you got it in the workshop :D
It would be great to get the engine purring as it should do :lol: It's practically brand new, less than 5000miles on it 8)
Can't wait for the progress updates Dan - it's pretty exciting :!:
It's like Tank Overhaul and Time Team put together :lol: :lol: :lol:
Do good things - and good things will happen to you!
welshrussell
Postby bigmastif » Mon Feb 09, 2009 9:43 pm
welshrussell wrote:It's like Tank Overhaul and Time Team put together :lol: :lol: :lol:
better hope it aint like chop shop meets wrecks to riches......................infact you should :lol:
bigmastif
Postby jolly olly » Tue Feb 10, 2009 12:26 am
Hello dan, can you confirm the paint scheme or is that a secret for now cheers.
Life is not a dress rehearsal
jolly olly
Postby Dan T » Tue Feb 10, 2009 12:51 am
I'm hoping to get as many pics as possible along the way :)
The paint scheme will be the same as present and only the cab and inner door steps will be sprayed.
The biggest job will be the removal of the wings because of the welds, Although this will allow us to look for anymore rust lurking behind panels which will be cut out and new peices welded in and sealed up.
Dan T
Postby jolly olly » Tue Feb 10, 2009 1:14 am
Not sure if its been posted as what you will be replacing yet? It will be interesting to watch the progress on this one.
jolly olly
Postby welshrussell » Wed Feb 11, 2009 7:45 pm
jolly olly wrote:Not sure if its been posted as what you will be replacing yet? It will be interesting to watch the progress on this one.
Sorry for hi-jacking your thread Dan :oops:
The big jobs planned for the van are to replace the nearside lower wing, doorstep and sill, windscreen rubber and straighten up the offside wing (badly fitted by another garage). Also a couple of holes welded up in the offside doorstep and floor pan.
When this (and the other inevitable bits underneath) are welded up, the van will be resprayed in its current/original Fjord Blue 8)
Once Dan has fixed the outside, I'll get cracking on the inside with painting the cab floor and then recovering it with rubber matting.
I also plan this Spring to get my gas cooker fixed in permanetly, drinking water pipes replaced, door cards and seats recovered, buy a fridge and try to give the rear bodywork a good thorough clean :D
Also add the thousand little jobs like replacing rubber fuel pipes, wiring, chrome polishing, etc :o
Sometimes I think this van will keep me busy for the rest of my life :lol: :lol:
welshrussell
Postby jolly olly » Wed Feb 11, 2009 7:53 pm
Yip it does sound like you will be busy but well worth it.
jolly olly
Postby Dan T » Mon Feb 16, 2009 9:08 pm
Well today we made a few adjustments and she now starts easier (second Crank usually does it) still running rougher than desired, but with some fine tuning it will smooth out :D
We also discovered the choke dosen't do anything when pulled out, so furthar investigation is required...
More pics soon...
Dan T
Postby welshrussell » Mon Feb 16, 2009 10:04 pm
We also discovered the choke dosen't do anything when pulled out, so furthar investigation is required... :shock:
Nice one Dan, great to hear she's starting easier :D
I can't beleive the choke wasn't working - no wonder she was such a bugger to start on those cold mornings :shock:
I'll be well chuffed when you manage to fix this :D
welshrussell
