Mk5 Chassis Cab Restoration
Postby ginsambo » Tue Jun 02, 2009 2:27 am
Inspired by Shelby Mustangs :lol: , a fear of Rusty Mk6's, a love of Mk5 Pickups, a new (Warm) shower, a Thatcham Mk5 Body repair manual, a Mk5 Chassis Cab with a chassis that is way too good to scrap and the promise of a good run of work for the next 4 months, I've decided to start a post on restoring my Mk5 Pickup.
I'II be modding it later, and I'II be putting a 24V Cosworth Boa in it too for a mock up. But I'II stick with the restoration theme at the mo as knowing me it will probably take me the best part of a year by which time I'II have every panel disassembled.
I want to try and take off both the inner arch panels in an effort to eliminate the rust between the spot welded seams.
My idea is to remove rusted panels and crossmembers etc. completely, repair them, get them and the rest of the Transit shotblasted and then put it back together again. Mk5's aren't like the good old Mk1 -3's, as the rust seems to creep in everywhere and cause major problems and there seem to be that many more factory laminations that are done to a far shittier quality of build.
I am only thinking of doing the repairs this way as I am in no hurry and judging by the quality of Fords Panel joining work will probably look as good when it all done. (No disrespect to Ford Assemble Workers but it is a slur on todays Robo tronics and throwaway culture which is instigated from the top).
Being a chassis cab its a little less daunting than a van so I am thinking I will remove as much as possible without the need for an alignment jig.
I'II be taking the upper chassis rails off complete with crossmembers so as I can get inside the lower chassis members and put in some new laminate steel to replace the ones that are starting to rust out. Don't actually think by the condition of it that the outer chassis section will need a repair, as its just bulging inwards between the spot welds along the tail end bottom side of the lower chassis rail from the expansion of the rust from the inner lamination. It should just hammer out straight, though if I need to patch it it will be seam welded.
Chassis Cabs have a hard life, much more so than Tourneos and GLX minibuses so they are impossible to get in pristine nick, although the other MK5 I am running comes pretty close.
I'II use this one as a learning curve, especially in learning how to tackle those hidden laminated water traps that start bulging and bursting open with rust despite the maintenance and genuine low mileages.
If I just repaired it it would get through the MOT, but really I want more than another 3 years tops out of it.
Here is the result of Sunday and this evening so far: Engine Gone, Shocks off, Seats & Dash out, Wing off, started removing some more spot welds...
Well here it is.
Wing off - found it had been repaired and the bodgers (Well, time is money) drilled right through to the inner A Pillar Panel with the spot weld drill bits when they got the old factory wing off, needless to say they left it as untreated bare metal and the damp got in between the outer and inner A pillars, so a bit more work in line...The initial accident damage and the repair probably contributed to the erosion, although offsides are always bad.
I've been using spot weld cutters and am finding they don't last very long so that is going to be a few £££'s... Been using another drill to drill a small pilot hole half a panel deep to guide the cutters, I think I need to get the spot weld drills as it will be a lot easier and no grinding off the weld nuggets afterwards.
Been scraping off the underseal and seamseal in an effort to track down the elusive spot weld positions and mark them off with a pen, think I have them all now. I wasn't planning on it as there is no rust here, but I'II have to separate the two inner wheel arch panels after all as the inner A pillar is spot weld sandwiched between them. Using a bluntish chisel to scrape off the underseal and its not damaging the primer any (It will stay outside for a while yet) :roll:
What is this extra laminate reinforcement for?? Lifecycle design? I think Ford introduced this when they redesigned the MK4 with 90 degree extra mount brackets, as the MK4 with 45 degree brackets featured a one piece chassis top and bolts & saddle to secure the mounts brackets to the top of the chassis. I want to get shot of this chassis top plate too as its paper thin around the edges. I think I will have to use some spot weld drills for the short section that it underlaps the cab floor, where it ends as there is no other access and the weld nuggets from a spot weld cutter wouldn't stop it being freed from the cab.
Anyway once this top chassis plate is out if the way, I can get inside the chassis leg....and possibly remove the sandwiched inner leg too...see how it looks when I'm there :roll: Rather than grind them all off, I'II be leaving some weld nuggets on the remaining panels so I don't get any hassles with panel alignment when it has to be put back together again.
Trying out some 45 degree MK4 engine mount brackets I acquired the other day, all line up OK and should (In theory) marry with the SVO Cologne V6 engine mounts, I hope.
Anyways, for a first timer, lets hope I don't end up with a pile of disassembled scrap metal a few months down the line.
Taking things apart is a whole lot easier than putting them back together again and I live in hope! :lol:
Humpty Dumpty springs to mind! :lol:
I hope this thread will be of some use to someone as a referance for how MK5's are actually put together, I'II try and keep it to the point, but if it gets too long I'II have to be putting in some charitable donations for the server space. :lol:
Anyway less words!!
ginsambo
Re: Mk5 Chassis Cab Restoration
Postby HughieVanMan » Wed Jun 03, 2009 6:48 pm
Nice one ginsambo!
Looking forward to your progress with this project. Good descriptive captions and pics. Keep it comin'! :P
"Where did you get your good judgement?
From my experience.
And where did you get your experience?
From my bad judgement."
HughieVanMan
Postby noobrider » Wed Jun 03, 2009 8:19 pm
definately one to watch. keep up the good work and best of british
noobrider
Postby ginsambo » Sat Jun 06, 2009 8:26 pm
Had to work most of the day and that's about it for this evening. One more panel off. Hope these photos show the spot weld positions, though if you really needed shot of the lamp panel you'd probably grind it off anyhow! :lol:
Also managed to free the inner wheel well from the chassis top plate but starting to bodge it with normal drills and a hammer & chisel as the cutters are all blunt, so enough is enough for now, until I get my spot weld cutters and drills in the mail....Yep..I should have used the cutting compound from the start, donno why I didn't as I wouldn't think about drilling without using it! Wouldn't mind one of those short mini drills for those tight spots between panels.
At least it reassuring to know there is rust between every panel I've taken off so far, maybe minus some the lamp panel.
Still hasn't rained here, crap for work but at least the turf isn't curling up as you lay it anymore with the odd cloud about.
Great weather for my rusty Transit but!!
ginsambo
Postby intransit89 » Sun Jun 07, 2009 1:39 pm
8) 8)
intransit89
Postby ginsambo » Sun Jun 07, 2009 11:00 pm
Still waiting on the post so going off at a tangent a bit...Someone must have sacrificed themselves to the rain gods last night as I spent most of the day drying out a flooded garage that was 2 inches underwater....Tryed out some running boards I had in storage for the last two years, only got them out because the boxes were soaked. I'II try & make some fibreglass up for the 'Cosmetic' ends. I think the doors/windows will need chopping with them on as the chassis cab transit doesn't look meaty enough on top when a lower skirt is added, infact it just looks like a stock van thats been chopped in half. :?
I've got a few spare doors, next time I get a chance I'II try and joggle up some chopped ones...only problem is that the flexovit discs are in the post too though. When I got the boards I had this wild idea to get some repro Ford Model T running boards and inlay them in the rubber tread....all in the name of Transit 190...well I even despair at myself sometimes... :lol:
ginsambo
Postby jerry2 » Mon Jun 08, 2009 11:05 pm
What a good idea.
Looks like the best way of doing things.
Good luck with it.
jerry2
Postby ginsambo » Sat Jul 04, 2009 9:59 pm
Right...been back at it again. Inner wing is off (and rusty/non-existant/battered to hell), wheel arch is off and also rusty but came off clean.
Front chassis leg closing section is almost off, damn floor pan is in the way.....grrrrrr.
Tempted to take the whole bloody floor pan out but since I'm removing some of the outriggers I fear the whole tincan might sag down a little so see how it goes....it makes no sense to cut it out exactly around the chassis leg to gain access to put a butt weld in later as this would weaken the thing too much I reckon.
Chassis not too bad..good actually..but....a big bulge on the side where the rust has got between the inner laminate chassis section front leg and actual main outer chassis.....so I wanna take out the inner chassis leg - being a purist like with no idea!! Might even replace it with 4mm box section after seeing the 5 Star safety raters on the road these days that its up against. :lol:
Don't know what the hell I'm gonna do about the removed panels. Plan was to remove them cleanly, shot blast, paint, then grind out clean the plug weld positions, spray with weld thru primer and refit!! Ha Ha, now I have a pile of rusty twisted crap. Not worried about bodging up the inner wing as its 0.8mm but the wheel well/arch where the shock mounts is structural and its a pig of a job to hack it out of another van. Transits always go here, right at the shock mount on the inner arch and at bulkhead/arch seam, I always though it was a lack of seam sealer and road salt but its seems like its because of the leaking plastic cowl screws combined with battery acid and a lack of seam sealer from above.
I've seen Mk1's stored outdoors under a tree in a field since 1976 with less rust between the spot welds than a Mk5...... :roll:
Anyway if anything comes of this it will be some pics - I'II put em up soon! Still, glad it ain't a van!! :D
Oh yeah spot weld cutters are a waste of space, expecially since my drill chuck is worn wobbly.
Spot weld drills defo the way to go!
Right, I'm off to talk transvestitism with some random stranger on OMegle...NOOOOOOO!! :lol:..Well all I can say is it must rain alot up north eh!! :lol: :lol: :lol:
That said, recently heard news that my cousin in Adelaide, Australia is getting married to some presbytarian Christ worshipping daughter of a preacher from Canada that he met online...and apparently she is really fit....hmmm.. Well, just maybe I'd have half a chance if it wasn't for all these god damn online tranvestites on Omegle!!
Damn man!! :lol: :lol: :lol: No seriously all that online meeting people shite is weird. He says.. :lol:
Anyone got any advice on clamping panels for plug welding that you can't reach with a clamp if you see what I mean?
ginsambo
Postby AlanN » Fri Nov 06, 2009 10:06 pm
How you getting on with this, or are you shacked up with a married Canadian
Postby ginsambo » Sat Nov 07, 2009 8:28 am
AlanN wrote:How you getting on with this, or are you shacked up with a married Canadian
:lol: :lol: :lol:
I've put it on hold until I get a new MTA welder and have the funds in place to get it blasted and primed immediately. Almost have the money sorted, then something comes up and it falls through my pockets. So its still under a cover. :oops:
The thing is I must of helped fix three other transits for other people in the meantime - new arches, wings, sill, made up front outriggers, floorpan sections etc. :roll: :oops: And each one has only taken about a week and a half of evenings after work. Regarding this one though I'm a bit of a perfectionist and look at it as all or nothing. But I'II admit, now that I've helped on these other transits that I have been a bit namby about going about it. I'm just paranoid about rust and weld strength. Before I stopped work I'd removed the offside inner wing with suspension mount and gone 'Oh Dear'. I'd like to get another panel at Tommo's but its just the £'s so maybe I'II try a repair.
Now that I've scrapped the SVO Van I have the space and I will be getting back with it soon though. I am fairly confident that once the front and rear axles are dropped we'll be able to lift it so I can get all the way around it to work on the thing. Floorpan will be coming out then top chassis rail and it will have to be fully supported. Then internal chassis strengthening etc. and also the front sleeved chassis section as thats bulging out too. This is why I'm waiting to get a decent welder. Could get a mate to do it but he's busy down the farm.
I have discovered that being parked under a big tree regulates the local humidity and more importantly temperature extremes (Although I already knew this from landscaping). The upside is that whilst it is generally more damp, the condensation from the sun warming up the tarpaulin during the day etc. is almost non-existant so anything under cover stays dry. Also there is less splashback underneath as the tree filters the rain and causes a bit of a rainshadow :D So there is a irrelevant handy tip if you have a big tree but no workshop! Of course you have to get rid of the grass and plants first - transpiration and local humidity from plants losing moisture will rot the undercarriage in a few weeks - that's where a few free ex-council pavers come in handy!
OK I'm stalling now :lol: I'II get back with it soon!
ginsambo
Postby ginsambo » Sat Nov 07, 2009 8:58 am
oops.
ginsambo
Postby aussieboy » Sun Nov 08, 2009 2:58 pm
Hi nice project !- I used to work on vehicles owned by the company named on the bonnet of your truck - is this transit a "p" reg ? .Aussieboy.
aussieboy
Postby ginsambo » Sun Nov 08, 2009 10:35 pm
Yep, that's the one. Ed at Landford Trees keeps asking me if I've got it on the road yet and I keep telling him 'Not yet no" :oops: So you were with Avery's or Hendy Ford's in Soton? They did offer me their Mk6 EXLWB as the fuel pump had gone. I've never seen anything as rusty to be honest. :( At least Mk5's are fixable.
ginsambo
Postby aussieboy » Mon Nov 09, 2009 10:57 am
ginsambo wrote:Yep, that's the one. Ed at Landford Trees keeps asking me if I've got it on the road yet and I keep telling him 'Not yet no" :oops: So you were with Avery's or Hendy Ford's in Soton? They did offer me their Mk6 EXLWB as the fuel pump had gone. I've never seen anything as rusty to be honest. :( At least Mk5's are fixable.
Hi yes I cant believe the chassis stayed so clean as when I last worked on your truck It had never had a set of rear wheel arches fitted and that was about 2006 ! is it still like it ?.
aussieboy
Postby ginsambo » Mon Nov 09, 2009 6:58 pm
Yep. They never fitted any arches - they gave them to me with the van, don't know how it got through the MOT's like it as Avery's are good but very strict. Most of the chassis is actually filled with mud and dust and the roof had a dent where they sat on it, riding around the paddock.
I'm a firm believer that blue, red and silver and even factory yellow paint is thicker than diamond white and the chassis is good. Slight bulge from one internal steel laminate brace rusting inside between the rear hangers offside and a big bulge under the front offside arch on the outside chassis sleeved section again from the inside section rusting and of course underneath where the water sits on the bottom chassis rail inner laminate strip. Hope to get to those and respot the inner laminates with new steel and bang the outside chassis skin into shape again when I get going on it again as I don't want to sit around and wait for the rust to blister through the outside chassis skin like they do.
I think the key to keeping it in good shape was daily use with some long trips and storing it outside in the sun all day. It must have been good nick when they got it from the hire company or previous owner. I think maybe they should have kept it as they seem to be getting through their MK6's what with the rust and fuel pump problems etc. it (Was) a bloody good workhorse and I've got its engine in my other pickup at the mo.
ginsambo
Users browsing this forum: Baidu [Spider]
