I use the internet through my mobile, while i am away in my van, which can be for weeks at a time, as i do security work. Due to this many of the pictures that i post wont be the best quality, as i have limited bandwidth, and only the camera on my phone. I will however endevour to make up for these shortcomings when i am back home.
My van is a 150L, has a passenger side sliding door, drivers side sliding window. It is currently diamond white, with fords own unique brown highlights (rust).
The rust at this stage is not too bad, in fact it is just surface rust at the moment, and im hoping it will stay that way for a while (till august) when i can get it resprayed panther black.
So far i have -
fitted orange beacons
run 12 x 12v outlets in three groups of 4 to various places in the back
run 240v mains sockets on both sides in the back
fitted 2 electronic (leave on all the time) battery chargers
fitted a 12v fridge (boy does this kil the battery)
Fitted Playstation 2
Fitted Flatscreen Digital Tv, and Magmount arial
moved rear bench seat back (leaving 1m between seat backs and rear doors)
fitted 75L Fresh Water Tank
Fitted 25L Waste Water Tank
Fitted 3 Mahoosive Leisure batteries
Fitted a Split Charging system to charge all the batteries whilst driving
Done the Fuel Pressure Mod
Fitted Curtains (To stop the theiving scum seeing whats inside)
Fitted a good alarm, with paging facility
Stuff to do --
Fit the supercharger (thread elsewhere)
Tint the windows (especially the back side sliding one)
Re-Panel the van, with all new looms behind the boards
Fit A bigger charger for the 3 battery pack (The one i got not strong enough)
Re-Upholster the headlining ( or steam clean, pm me if you have suggestions)
Add an external 240v power inlet for charging from home or generator
Add an external water filler flap, save loads of time carrying buckets of water out to the van.
Fit Voltmeters to both the main van battery and the leisure packs
Fit a thermostat to the 12v fridge to save power (dont know why they dont come with one, they freeze my milk
Fit an ammeter to the batterys too, just to make sure that nothing is draining the batteries when i dont want them too.
Paint the entire van panther black, with some hi vis (number plate style) checkers down the little 3 inch groove down the side of the van.
Fit a bigger tv
Fit a hard disc recording system and 4 cameras (it is a security van after all)
Fit a better version of sat-nav (fed up using laptop now)
fit some speakers and an amp.
Im sure this list will grow
[/img]
