Ex John Lewis MK5, 2.5TDi 85ps Automatic & Air Con.
Postby Nadjenka » Sun Jul 11, 2010 12:27 am
So here we go... :twisted: I've had this van for couple of months now, decision to keep it has been made, so it's about time to start a progress report. :D
My "new" MK5 ('cos they are worth saving :P ), ex John Lewis van, 2.5 TD, 85ps, Automatic with toys including leccy windows and air conditioning. Weirdly enough - no central locking :shock: and... oh yeah... it's GREEN :mrgreen:
As you can see, he had a hard life after retiring from John Lewis fleet :( Bruses, cuts and several bodges indicate some inconsiderate owners or maybe a blind man behind the steering wheel in the past :evil: Despite this being a MK5, it has all it's original arches, sills, steps, crossmembers etc, even the inner arches :shock: Surface rust showing, but comparing to many "younger siblings" MK6s, not bad at all me thinks :mrgreen: Luckily (yeah... I say that now... :roll: ) all of it appears to be surface scars, hopefully easy to get rid of... Image
:shock: :shock: :shock:
It has some metal left even underneath :shock: :shock: :shock:
Progress has already started, pictures and more stories to follow :D :D
Nadjenka
Re: Ex John Lewis MK5, 2.5TDi 85ps Automatic
Postby Nadjenka » Sun Jul 11, 2010 12:50 am
Bodge after bodge was revealed when we started to take it apart...
Instead of intake grill, there was ductape covering it (ductape - MK5's best friend :roll: ).
Air intake pipe behind it was cut, screwed with 100mm long screws and covered in filler :shock: Filler in the engine bay - now that's new :?
But it didn't end there... EPIC pump was leaking (now - that one is not new, is it? :lol: ), automatic gearbox is due for some upgrade and overdrive fix, so the decision has been made to take the engine out and do it properly :D
As you all know I'm useless when it comes to mechanics, so AndyG - man of the year, came to put a bung on my wallet and stop the EPIC pump from leaking the precious diesel all over the place :evil: 8) He located the leak on this pump from the most common place - square seal. Removed the mischievous Epic pump and repairs started... Here it is, looking all innocent :twisted:
Andy unscrewed the bolts on the plastic cover and removed it
Mark the position of the sensor and remove these two bolts underneath
And - voala - who would think that such a little seal can cause so much trouble...? :roll:
Aaaaall flat and not sealy at all now... :evil:
New replacement square ring goes on :D
And Andy closes the case of leaking Epic pump, all below 10 minutes and wayyyy below £5 8) 8) 8)
Refit is reversal of removal :twisted: :twisted: :twisted:
No more diesel leaks, no more trouble :!: You'd need 5 spanner skills (ref. Haynes) OR AndyGs hands to make this happen 8) Good time to change the timing belt, water pump, tentioner and - of course - set the timing 8)
Nadjenka
Postby psv-hgv-flt » Sun Jul 11, 2010 7:58 am
yes very common for that seal too leak, change the auto to manual and put some 100ps injectors in. :shock: :D
psv-hgv-flt
Postby madbri » Sun Jul 11, 2010 8:09 am
so will this van replace lolo? hope not after all ure hard work! but what ever you decide good luck :wink:
madbri
Postby madmark_50484 » Sun Jul 11, 2010 8:25 am
Got to love the green ones :D I used to have one myself but it was a murphy one
that van used to do well when I done removals. Anyway like the new one it looks a bit more solid than lola was he looks like a good friend for her.
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Postby Luke » Sun Jul 11, 2010 9:28 am
Nadjenka wrote:maybe a blind man behind the steering wheel in the past :evil:
or blind woman :mrgreen: :lol: :lol:
the van doesnt look that bad at all 8) i know the dark green helpis it look better in photos but it still looks a tidy base 8) plus it will have the high spec loom for future upgrades i'd have thought :D
Postby Nadjenka » Sun Jul 11, 2010 10:50 am
psv-hgv-flt wrote:yes very common for that seal too leak, change the auto to manual and put some 100ps injectors in. :shock: :D
:? :? Never gonna happen, this replaced my automatic Audi! I'll tell you what - automatic transmission slows down ageing and decreases stress and mortality... 8) Especially when doing deliveries in London :evil: Far less likely to kill the learner in front of me on the road who is only using second and third gear, AND - looking better doing that, 'cos I have less stress wrinkles to worry about Image
The automatic is staying,, so is the Epic :!: :wink:
madbri wrote:so will this van replace lolo? hope not after all ure hard work! but what ever you decide good luck :wink:
Nooooo :!: :shock: To be honest, I probably would never look other way when it comes to vans, but Lola was giving me such a grief back then, she broke down when we were busiest with deliveries and I sinned... :oops: I looked at another vans and found this one to be a bargain of the year. But it's not replacing Lola, Lola was supposed to be a camper, so she will :wink: This one will take her workload :D
Nadjenka
Postby Nadjenka » Sun Jul 11, 2010 11:02 am
madmark_50484 wrote:Anyway like the new one it looks a bit more solid than lola was he looks like a good friend for her.
Thanks, it is much more solid, but it also has soooo much more scars on the bodywork... :shock: Main thing was - he doesn't need any welding underneath 8) 8) I hear Luke shouting "Waxoiiiiiiil" from Rotherham... :mrgreen: That's what we're going to do at some point :wink:
Luke wrote:or blind woman :mrgreen: :lol: :lol:
Oh it's unbelievable how BOTH of my vans photograph better that they look in reality :!: Don't get fooled, there really isn't a panel on that van that wouldn't have a dink or more serious builder scar. :roll: It's not plylined from the inside, so you can imagine... :( But after Lola, who looked GREAT on purchase, I thought - it's so much better to see what you'll be up against! Seller didn't attempt to hide anything. Still don't know if it was a good buy or a nightmare, the time will tell I suppose :lol: :lol:
Yes - high spec loom helps - he will receive some more toys later on 8) , but this is going to be very long progress... :lol: :lol:
Nadjenka
Postby MurrayXmas » Sun Jul 11, 2010 11:35 am
You are a glutton for punishment :lol: :lol: Good luck!
WHEN I NOD YOU HIT IT!!
'96 190 lwb banana '99 Lwb Luton Banana
MurrayXmas
Postby madmark » Sun Jul 11, 2010 11:45 am
i am a big fan of auto,s you just cant beat them :wink:
the epic is good if you get a good one :wink:
i had a lwb auto with ac but the box started to play up ,this wasnt a problem till i looked undernieth the van and wow it was rusting like nothing i had ever seen so it was sold very quickly ,shame as it was a rare van with all the options! :(
1999 v reg :(
Postby AlanN » Sun Jul 11, 2010 11:47 am
Hmmmm! Aircon :lol:
Postby matthew2riches » Sun Jul 11, 2010 11:49 am
I can see this is going to be a good one. Nad - you've had the practise with Lola so lets see another gooden! :D
matthew2riches
Re: Ex John Lewis MK5, 2.5TDi 85ps Automatic & Air Con.
Postby AndyG » Sun Jul 11, 2010 7:41 pm
The worst part of that particular repair of the EPIC pump has to be doing the cam belt :!: :lol: as the part that needed access was on the engine side :evil:
So anyone that can change their cambelt on one of these can certainly deal with a silly little pump leak :wink:
Postby AndyG » Sun Jul 11, 2010 7:42 pm
MurrayXmas wrote:You are a glutton for punishment :lol: :lol: Good luck!
I think so too :!: :lol: :lol:
Postby MattBlackMinibus » Sun Jul 11, 2010 7:56 pm
Nice wagon Nada.
Auto Turbo :twisted:
Lucky Cow 8)
Starting All Over Again
MattBlackMinibus
