This is what remained after removing the piece that had fallen out and removing a badly welded plate from the area you can see.
This is the piece that fell out. I'll be re-using half of this piece but I need to cut off one of the square plates to enable me to pass this piece through the new repair section I've made as you can see below.
Waste not, want not - our old fridge came in useful for the metal to make the repair section. It's not as thick as I'd like but I'll be doubling it up and adding some strengthening bits to it.
And this is as far as I got .... repair section made up and almost completely welded in place but I've run out of welding wire so it will have to wait a while.
Next stage is to measure and mark out the hole for the tubular shock mount and attach it to the new repair section.
The fun of owning a very rusty Transit.... now I know how Fredrik feels although I wish I could weld as well as he does!!
