This morning i finished putting in a wireless reversing sensor and a nokia bluetooth kit in my 04 lwb which i have had a month now.
All electrics were a doddle although i did blow the 15 amp reversing light fuse.
Replaced fuse with same rating - everything worked except van would not start!!
Not even a click from the solenoid on the starter motor.
Several attempts turning the key it started. Stopped and started it fine after.
Took it for a drive and it did the same thing.
Only connections i used was the igintion live for hands free along with a positive direct to battery, grounded it to a screw i drilled in.
Reversing sensor is powered by reversing light.
I am confident i have not disturbed anything but i am lost for ideas but on my last van you would hear solenoid on starter at least click when the starter was faulty
Any ideas gratefully received
Thanks, Chris
