my new mk1 camper
my new mk1 camper
Postby boneheaddread » Thu Jun 30, 2011 4:46 pm
Hi , well I have just gone and bought my first mk1 transit , its a high top camper 1972 2litre v4 with a knackerd camshaft fibre gear ( I think from reading this forum ) dizzy rotor arm not spinning , nor fuel pump or oil pump ????? and plenty of rust in one wing and both the door bottoms , but I love it already and I took a punt at £600 , any help on parts and what the problem may be would be much apprecated , thanks john :D
boneheaddread
Re: my new mk1 camper
Postby madmark » Thu Jun 30, 2011 4:53 pm
john you need to strip the front cover off of the engine to check the fibre gear ,the gear is available in steel but is expensive :wink:
dont forget to put photo,s of the mk1 on the forum :wink: :wink:
Postby transitandy » Thu Jun 30, 2011 6:38 pm
Hi and welcome to the site :) get some piccies up when you get a chance :wink:
Postby boneheaddread » Fri Jul 01, 2011 8:09 pm
madmark wrote:john you need to strip the front cover off of the engine to check the fibre gear ,the gear is available in steel but is expensive :wink:
[/size]
Hi , I will put some photos on when I find my USB lead?
just took the timing gear cover off and the fibre gear is mashed in one place so when the crank spins it is just mashing the camshaft gear , there also looks to be some bent pushrods , should the camwheel spin with a spanner on the front bolt?? as it wont turn at all ?? is there anything in the top end tat would sieze the camshaft ???
any ideas
thanks john
boneheaddread
Postby MrMPuk » Fri Jul 01, 2011 9:11 pm
boneheaddread wrote:should the camwheel spin with a spanner on the front bolt?? as it wont turn at all ?? is there anything in the top end tat would sieze the camshaft ???
If a piston is against a valve then you wont turn the camshaft. :wink:
Postby boneheaddread » Sat Jul 02, 2011 1:34 pm
Hi , but the crankshaft and pistons turn ok?
how do I attach a photo of the van ?
boneheaddread
Postby MrMPuk » Sat Jul 02, 2011 1:39 pm
Yes because it has already bent the other valves.
Postby boneheaddread » Sat Jul 02, 2011 4:25 pm
Hi , ok just took the rocker covers off ,got one bent valve second from the rear on the right side looking from the front, camshaft is noe turning ok with a socket on the crankshaft bolt
boneheaddread
Postby MrMPuk » Sat Jul 02, 2011 4:30 pm
:wink:
Postby boneheaddread » Sat Jul 02, 2011 4:44 pm
Hi here are the pics
[img]http://i602.photobucket.com/albums/tt10[IMG]http://i602.photobucket.com/albums/tt107/boneheaddread/087.jpg[/img]7/boneheaddread/086.jpg[/IMG]
boneheaddread
Postby MrMPuk » Sat Jul 02, 2011 5:01 pm
boneheaddread wrote:Hi here are the pics
Postby oldyellar » Sat Jul 02, 2011 6:19 pm
Is that a sterling castle parked next it? :D
oldyellar
Postby boneheaddread » Sat Jul 02, 2011 6:41 pm
Hi no its a 1970 11 ft safari , dont suppose anyone has got a fibre camshaft gear and a set of pushrods they would like to sell to me ??????
boneheaddread
Postby transitandy » Sun Jul 03, 2011 8:11 pm
looks a nice one m8y :)
Postby boneheaddread » Mon Jul 04, 2011 12:28 pm
Hi , hopefully sorted the fibre cam gear , does anybody have any idea where I can get a set of pushrods and possably a set of valves from????
found a place on line in germany www,oldcars ? they seem to sell everything for the v4 has anyone used them before???
thanks john
boneheaddread
