dave this is a tricky one ,yes pas can be fitted but will cost loads to do, as you will have to sorce a steering setup from a mk3 transit , the van will have to be cut around abit as well to make it fit! the pas steering boxes are very hard to find though!
if you pump up the tyres this will hep abit when you are on the move it will be ok! most erly transits diesels i have owned never had pas and i didnt find it to much of a problem! hope this helps you mate mark
